HOW do you install Solid Motor Mounts!!??
i know the concept of how to install them but we have to many cars at the shop to put them on there so what is the best way to install them in the garage with the car jacked up a few feet? i know there are a pain in the *** but any tips and tricks i will really apprciate!!
You need to hold the weight of the motor up slightly. I would put the front on ramps, hook a chain to the heads/top of the engine, hoist up on it slightly and loosen the stockers, remove and replace to the solids. I would think the ac compressor and bracket would need to be removed and tied out of the way, and the alt removed. Then you would have unrestricted access from the front.
When I put in my spohns, it took about an hour. Remove Alternator, Unbolt and move forward the A/C and remove the bracket. I used a jack under the oil pan with a wood block to hold up the motor. Jack it up slightly, remove the stock mounts and pedastals. Its more of a pain getting them in the right way than anything, loosely bolt them up to both sides and let the motor down, then tighten all the bolts.
NOTE: intake will hit a strut tower brace if you have it intalled so you might want to remove it first and see the clearance before jacking it up or putting the solids on. With my spohn mounts the intake hit the brace and I had to remove it.
just installed my solid mounts everything went very smoothly just had to faness (or how ever you spell that) the driver side in but thye install went very well!! thanks yall
