Which is better ls6 or ls2 intake
Old 11-20-2010, 09:01 PM
transam8410's Avatar
Default Which is better ls6 or ls2 intake
I just picked up a good deal on a fast 90mm tb, now looking for the most cost affective intake, I've been looking around and finding that ls6 intakes are only 78mm, but the ls2 intakes have 90mm openings anybody have experience with this or any input
Old 11-20-2010, 09:08 PM
ULTIMATEORANGESS's Avatar
ls6 but id look for a used FAST.
Old 11-20-2010, 09:41 PM
lubelizard's Avatar
LS6 flows better than LS2, but LS2 has the 90mm TB. Find a used Fast 90/92, or a ported LS2 intake.
Old 11-20-2010, 10:00 PM
Darkman's Avatar
http://www.ls1gto.com/forums/showthread.php?t=289456
Old 11-21-2010, 12:06 AM
garygnu's Avatar
get the fast or any 4 bolt alum intake,BBK etc..they are better then the ls2 intakes .
Old 11-21-2010, 06:14 AM
Engine_HP's Avatar
if both were stock id pick the ls6, if both were ported ill pick the ls2 for sure.
Old 11-21-2010, 08:40 AM
Darkman's Avatar
http://www.highperformancepontiac.co...o_results.html
Old 11-21-2010, 09:58 AM
LS1-450's Avatar
Old 11-27-2010, 08:45 AM
98LSGun's Avatar
Question regarding the ls2 intake.. i just picked up a ported one, with a nw90 tb, Question is converting the fuel rail, im told i cant use an ls1 rail, so now do i switch over to a stock ls2 or find an aftermarket one?
Old 11-27-2010, 09:25 AM
SILVER 2288 SS's Avatar
Location: boaring place where theres more cows than people
im interested in knowing about converting the ls1 fuel rails for the ls2 as well
Old 11-27-2010, 09:36 AM
King Nothing's Avatar
yep switch over to a stock LS2
Old 11-27-2010, 06:43 PM
Is everything interchangable
Old 11-27-2010, 07:01 PM
Darkman's Avatar
The answer depends on what you mean by "everything." LS!, LS2, and LS6 intake manifolds are interchangeable in terms of bolting to any one of the three motors. The throttle bodies are not the same size and not insterchangeable in terms of bolt patterns. Finally, the fuel rails are not interchangeable, but can be adapted in some cases.
Old 11-28-2010, 09:08 AM
yeah the fuel rail is what i was refering to how do you adapt it
Old 11-30-2010, 12:18 AM
does it just attatch to the fuel line like the ls1 rail does
Old 11-30-2010, 06:51 AM
Darkman's Avatar
The LS2 OEM fuel rail was a direct substitute for my LS6 fuel rail in terms of fuel fittings, so I believe it is also a direct substiute for an LS1.
