Speed Density Tune with Open LT's
Moderator
The only problem is, with speed density your tune embeds
the exhaust restriction as-tuned into the VE. If you add
pipe & mufflers later your VE will be unrealistically high at
higher airflows and you would bend the tune rich.
what about with a little bit of pipe with bullets off the headers or a y with a bullet off of it. I know of people running bullets that have lost no performance what so ever. In other words open headers and bullets shouldnt be that much of a difference considering their flow comparisons correct? The reason i ask is because i would still like to cruise city streets every once in a while, therefor i would want to add a little bit of an exhaust
