Anyone interested in an M29 LS1 T56??
I have an M29 (the lower geared 1993 model T56). I'm converting it from LT to LSx style. It has the lower gear set (2.97, 2.07, 1.43, 1.00, .80, .62) compared to stock (2.66, 1.78, 1.31, 1.00, .74, .50). If your T56 needs a rebuild and you are planning on sending it in for a Stage 2 build, then I can replace it with these lower gears for NO ADDITIONAL CHARGE!
Just pay the amount that it takes to rebuild your T56 ($680+additional parts + shipping). Check the website in my sig for all the details about the rebuilds we offer.
Before anyone asks, this gear set is exactly the same as the stock LSx T56, but the tooth count is different. They are not weaker or inferior in any way. I warranty my builds for one year regardless of mileage.
This is just something that I ran across, and I really like building unique setups like this
Jason
Jason
Actually the 2.97 ratio gear kit is weaker than the 2.66 ratio kit. Its better suited for stock or near stock F bodies though as they lack the torque to really use the 2.66 ratio without going to deeper gears in the rear. Even with the higher final od ratio, when you consider a 3.42 gear is going to run like a 4.10 with a 2.66 geared box, all things are pretty well equal and you don't have to worry about cheap after market 4.10 gears whining in your 10 bolt.
... and the actual M29 has a shorter (LT1 length) inputshaft. You can use the GM Aftermarket input, but then it's 1/2" longer than the LS1 input.
The M29 input gear and countershaft gears are thinner (gear length) than any of the other '94-'07 GM T56 gearsets, and the height was made up by a different bearing race depth in the specialize '93 front plates..
You'd really be better off converting over to a GTO setup unless you're putting this behind a stock 5.3l motor...
As Mike (thesource) said, it really is a weaker setup...
This gear box would be like having 3.85s in the rear when compared to a 2.66 T56.
Anyway, just throwing this out there for someone who might benefit from this setup. I stand behind the parts/labor 100%. I'll even warranty this for 2yrs instead of the normal 1 year
My only point is the "weakness" of these parts in the M29 tends to get blown way out of proportion.
I'd want the 2.97 / 1.94 / 1.35 from the retrofit version, intended for '83-'92 Camaros, combined with the 0.74:1 / 0.50:1 from the Viper, for the stronger tailshaft. Surely that 1.94:1 second will survive pointless powershifts better than the 2.07:1, while not being as stupid as the Cobra GT500s stupid 2.97 / 1.78 combo. Drive one, you'll hate it. But drive a T5 with 2.95 / 1.94, that's fine.
But I'm not willing to spend more than $125 on any trans, since that's what my local salvage yard charges for whatever I can find. Including 4L80Es.
2nd in the aftermarket box is 2.07 and doesn't differ from the '93 M29 box.
Enjoy that salvage yard.
