So it decided to die on me....
The other day i came out and it wouldn't start. It cranks and acts like it wants to start but will not.
This is what's been done to it recently.
Fuel pump/filter/relay
Plugs/wires
Ignition relay/starter relay
Last night I shook the battery and coincidentally it started up. But the auto part store was closed and I couldn't really take it anywhere.
Plugs/wires
Wonder if the FPR is having issues. Checking fuel pressure is a must. When in doubt the big 3.... Fuel pressure, spark, compression. If you have a good volt meter or an o scope check the injector plus for reference. You should see the ECU opening and closing the ground side. Ignition on +12 volt to ground on one wire always.
The ECU sends the fire signals to the coil packs based on the readings from sensors. Takes knock, MAF/MAP, TPS, and temp into account and adjust spark on those tables in the ECU.
But yeah you can get a spark plug, unplug the spark plug in the head and attach to the solo plug. Hold that plug against the block or a good ground and have someone crank it over. You can see the spark. You can also use a current clamp and a meter / scope.
