lookin to quiet my duals up some
Old 11-28-2010, 04:15 PM
meatyz's Avatar
Default lookin to quiet my duals up some
i have a 2002 camaro cam and full bolton i have lanes duals dumped bullet mufflers what can i do to quiet it it some?
Old 11-28-2010, 04:21 PM
bayer-z28's Avatar
cats? cat back instead of the dumps?
Old 11-28-2010, 04:41 PM
meatyz's Avatar
yea i was thinking about doing something to my setup now maybe a differnt type of bullets?if i remember correctly people where putting a spintec bullet to quiet it some but im not sure
Old 11-28-2010, 05:09 PM
ULTIMATEORANGESS's Avatar
magnaflow mufflers with tail pipes out back?
Old 11-28-2010, 05:21 PM
bayer-z28's Avatar
Add cats?
Because of how short the overall exhaust is, and the area of where the mufflers will go, this limits your choices. the short exhaust is going to be pretty loud unless you find some crazy way to rig some Flowmaster 60's in there.. 0_o
Old 11-28-2010, 06:27 PM
TXZ28LS1's Avatar
i dont know if adding cats will be a good thing. if you add cats, your clearance will probably be rough man. I dont know how to quiet duals. maybe just swapping out mufflers. but i wanted louder so i went from magnaflow catback to dynomax bullets.
Old 11-28-2010, 07:00 PM
01boydws6's Avatar
I put tails on mine and it is nice a quiet inside...
Old 11-29-2010, 09:48 AM
krissoto's Avatar
get rid of the dumps and run it out the back.
Old 11-29-2010, 10:02 AM
King Nothing's Avatar
LS1Tech 10 Year
run it out the back under the axle like a cobra exhaust and use sweet thunder resonators and it will quiet it down SOME but if you really want to quiet it down and avoid attention get a stock cat-back and a cut-out
Old 12-01-2010, 01:47 AM
Trev_SS's Avatar
switch to a longer round muffler under there should queit you down some something like a spiral flow or a twister.
Old 12-23-2010, 07:46 PM
meatyz's Avatar
im thinkin about giving the dynomax ultraflos a try anyone else running em?
Old 12-24-2010, 10:53 AM
thislswon's Avatar
Just run your current setup out the back and should quiet it and reduce drone inside the car...
Old 12-24-2010, 02:05 PM
manfred717's Avatar
I am running a magnaflow bullet dumped and it is pretty quiet. I posted a sound clip in this forum not to long ago if you want to hear it.
Old 12-25-2010, 06:34 PM
AAK z28's Avatar
run moroso spiral flows there not as loud a dynomax bullets
Old 12-26-2010, 02:04 AM
somws6bird's Avatar
Check out the dynatech turndowns with cone inserts welded into them
Part # M80-00100 you can slip them on and off easily
Old 12-26-2010, 02:19 AM
RyanJM's Avatar
I just added 2 bullet cats 3"in and out about 4 or5" long and quoted my catback down after the cam and reduced the gas smell.
