Textralia OZ700 Series Z- Grip Clutch......NEED some advice
Old 12-06-2010, 06:02 PM
cwdub4's Avatar
Default Textralia OZ700 Series Z- Grip Clutch......NEED some advice
Hey guys I got 99 Camaro SS i want to get a new clutch, car is stock and not going to do anything to it i juat want a very good clutch cuz i just bought the car and the person before me put a new one in and didnt install it right and just want to replace it.
I was looking at this one: Textralia OZ700 Series Z- Grip Clutch & Billet Steel
Flywheel
is this a good one? and also what else do i need to get with it? the website has some options so should i just get all the options and the clutch, this is what the options are:
-ARP Pro Series Flywheel Bolt Kit
-GM Clutch Slave Cylinder
-GM Flywheel Bolt Kit
-GM Hydaulic Clutch Main Cylinder
-GM LS1 Pilot Bearing
-GM LS2 Pilot Bearing
little help please guys Thanx
Old 12-07-2010, 07:01 PM
cwdub4's Avatar
Default come on guys...
no one can give me some advice? All you guys in here cant help me?
Old 12-08-2010, 07:35 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I use the Z grip, perfectly streetable/driveable. As described by Textralia is X grips are girls and Z grips are for Boys lol.
Either way its one of the best clutches I have ever owned and doing quite fine going on 3 years later.
I used all the parts supplied for the kit. GM pilot bearing, 02+ Slave, Tick Performance Master Cyl. ( you NEED THIS ). I have had stock and the close to stock RAM adj. which worked but not as well as the Tilton based Tick unit.
Old 12-08-2010, 04:56 PM
kc533's Avatar
Z-grip here w/ the mods listed below. Two thumbs up and highly recommended. Although I do agree the X-grip may be better suited to your application, especially since you say you're planning on staying stock.
Old 12-09-2010, 07:55 PM
cwdub4's Avatar
Ok I think imma go with that one then, thanx guys! also where can i get that tick cyl. thing at?
Old 12-10-2010, 12:16 AM
kc533's Avatar
LoL, Tick Performance..... http://www.tick-performance.com/
Old 12-10-2010, 09:00 PM
MR2liter's Avatar
If your gonna stay relatively stock I'd go with an ls7 clutch!
Old 12-16-2010, 10:32 PM
01bird58's Avatar
Do you HAVE to purchase the flywheel with the textralia clutch? It seems everywhere I look it is only sold as a package. Is buying the clutch only possible?
I would steer clear of the LS7, have heard this doesnt stand up well to moderate abuse.
Quick Reply: Textralia OZ700 Series Z- Grip Clutch......NEED some advice
