v6 has a bad stumble at 70
Old 12-08-2010, 04:11 PM
layz's Avatar
Default v6 has a bad stumble at 70
We just put headers and blocked off the egr on my buddies 3800 series 2 camaro..i think its a 1999. We took it for a drive the other day and got cruising at 70 and then punched it, it had a bad stumble and popping or what ever you call it...It would not go past 71..We just replaced the fuel pump and still no idea...what could it be...Oh and we did block the egr. All the 02 sensors are in, but one of them broke so we just used it to block the hole in the exhaust...i know we got to replace that, but if that dont work what could it be..
Old 12-08-2010, 04:37 PM
Ls1ChevyII1963's Avatar
Was it the front or rear 02 sensor that broke?
Old 12-08-2010, 06:27 PM
Super-Bat's Avatar
If it's a Pre-Cat o2 sensor, that'll cause stumbling like that.
Also, coil-packs are notorious for failing on these engines.
Any SES light?
Old 12-08-2010, 06:29 PM
5w20's Avatar
Why did you replace the fuel pump? Was pressure low or dropping under WOT?
Old 12-08-2010, 08:39 PM
JoeKnowsBaseball's Avatar
Possibly a cat... My gf's V6 bird wouldn't go past 70 sometimes when her cat went bad. Maybe when you pulled the EGR off, you knocked a bunch of carbon down the hole that damaged the cat or maybe whatever you used as a gasket has damaged the cat.
If you used any kind of silicone sealant, that will **** up a cat quicker than you can say oops...
Old 12-08-2010, 10:57 PM
WarShrike's Avatar
What headers did you install?
Replace that 02 sensor pronto.
And did you change the plugs and wires? The straight boots will have a tendency to burn on some of the aftermarket headers. I'd recommend getting new wires with 90° ends and might be a good idea to invest in spark plug boot protectors.
Old 12-09-2010, 10:38 AM
slow96z's Avatar
The cat in my 96 V6 firebird broke into pieces and one of them flipped sideways in the shell blocking flow, caused a similar issue. Bang on the cat and see if it rattles, could easily be the problem.
Old 12-09-2010, 12:01 PM
layz's Avatar
no cats and they are pacesetter headers
not sure what 02 sensor it was...i did not put them in..
plus its not my car..
have to check on if its throwing codes or not...
Old 12-09-2010, 10:38 PM
WarShrike's Avatar
Sometimes it won't throw a code. I had a plugwire get burned, it'd buck/studder when on the throttle but was fine at cruise. No codes, even HPT didn't pick it up.
Have your buddy get the O2 sensors replaced (do both sides (left header and right header), it's a great idea to go ahead and have both sides working properly.
Get him on www.fullthrottlev6.com and we can set him straight on any issues.
Old 12-09-2010, 10:40 PM
bad2dbone's Avatar
I would say cat. converter or def. 02s def. running lean somewhere......
Old 02-02-2011, 11:37 AM
benoh's Avatar
had a similar issue with my 99 V6.
To my understanding, the issue is caused by the transmission. I was informed that either rebuilding the transmission and / with adding a shift kit with a Corvette servo eliminates the issue.
You might have better luck researching the issue on a couple of V6 3800 forums.
Old 02-02-2011, 12:50 PM
ramairracer's Avatar
probably a cracked spark plug when you pulled the old manifolds off
