Who delete's KR
Old 02-06-2004, 08:45 AM
LS1Tech Sponsor
Slowhawk's Avatar
Question Who delete's KR
I've noticed a few cars lately coming to my shop with the KR taken out.So the computer does not pull timing like it should.
I'm highly against it,but was wondering how many people have actually tuned and deleted KR?
Old 02-06-2004, 09:06 AM
Big Mike's Avatar
I had the Knock Retard removed from my PCM in my first MTI heads/cam setup. Jayson at MTI recommended that I not have it removed, but stupid me removed it anyway. Having it removed was the reason for my 80% leakdown results and chunks missing from my ringlands on pistons 3 & 5. I'll never make that mistake again. See the pictures:
http://community.webshots.com/photo/...49283765fRQpRl
http://community.webshots.com/photo/...49283840UCtRAd
Old 02-06-2004, 05:14 PM
NoGo's Avatar
BIG HP setups you have to can KR.
Big nitrous motors you have to can KR
Anybody who runs solid motor mounts you have to can KR.
Anybody who is making in excess of 650-700 HP should have thier KR taken out, because it IS NOT going to save your motor. All it is going to do is slow you down at the track.
I have removed the KR on quite a few vehicles. I don't recommend it for normal street setups, but its not like the car is going to spontaneously explode if it is removed. I have also pulled it on several 98's with the dreaded false KR problem when specifically asked.
Old 02-06-2004, 05:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
I under stand big HP cars.So far I've seen this on 3 street cars that the owners didn't even know it was pulled..I was actually surprised to see 2 mild H/C cars and 1 bolt-on car with this done..
Old 02-06-2004, 05:25 PM
2001CamaroGuy's Avatar
I removed it because the sensors were shot (got water in them). I was going to replace them but now that I am doing solid motor mounts I won't be able to use them anyways. I just tune the car to not knock (a little less that 100% advance) and always run the best gas I can (have never had a problem).
Old 02-08-2004, 08:51 PM
Restricted User
CAT3's Avatar
Slowhawk, are you talking about low matching High Octane tables? If so, I have mine set to take 2* out.
Old 02-08-2004, 10:04 PM
LS1Tech Sponsor
Slowhawk's Avatar
No,I'm talking about deleting the KR completely.There is a table you can set to max KR.Ussually this is set to 4 degree's.
I just found it rather disturbing that the H/C cars had this deleted without the customer's knowing.Timing was set to 30 and 32 degree's and when we dyno'd the A/F was over 13-1 and could here pinging (no timing being retarded)
So,just seeing how many people actually do this..
Old 02-08-2004, 11:18 PM
Restricted User
CAT3's Avatar
No, I wont do that, sounds like hitting a hooker up w/out a condom, too risky for me at this point...Cam only, and a little spray here and there.
Old 02-09-2004, 02:33 AM
Fetumpsh's Avatar
Originally Posted by Slowhawk
No,I'm talking about deleting the KR completely...
Mmm, remove KR completly, might as well put a carbie back on too.
Old 02-09-2004, 04:18 PM
deezel's Avatar
I have reduced the Max KR a bit (from 8 to 5) and decreased the KR sensitivity 10% around a troublesome RPM range. Made these changes mainly to make tuning A/F less confusing. Changing the max KR to a different value in each table lets me know which table is being referenced when KR is applied. I have no plans to completely disable the KR system.
