I pulled the heads today, pictures inside please take a look
I am in the process of H/C swap and the car has 50,000 miles, I think it has been running rich for a while now. What do you think of these pistons, It looks like a lot of buildup to me, and one looks rusty???
opinions please........
Oh well, the project goes on. Today I got the solid motor mounts in and the new cam went in. Tomorrow heads go back on and bolt everything up
All of the plugs look good, they only have about 6-8K miles on them.
This is a pic of the head from the "rusty piston"
and the spark plug up close
Internet Mechanic
WD-40 and Scotch Brite Green or Red pads works wonder on combustion chambers, deck surface, block surface and tops of pistons. Whend done, hit with Real Brake Cleaner and wipe down with a low fiber yield towel and unless the heads have been warped, you should not need anything more.
The Piston color looks like a stain, but again that will be done once you clean them up. Also get a catch can when you have a chance, it should reduce any future build up.
