ls1/th400 c10
ls1/th400 c10
got a question im in need of a proportioning valve for my brakes ( drum no power) and i cant hardly fine the right one for the truck, does anyone know if you can use a universal one? or one from a different vehicle as long as it has the same locations for the brake lines? thanks alot
I have used the Wilwood adjustable proportioning valve many times, either the 260-10922 or the 260-8419, selection depends on the inlet and outlet sizes You need. Here is a link
http://www.wilwood.com/MasterCylinde...derValves.aspx
to the Wilwood site but they can be purchased from Your favorite vendor here on LS1 tech.
Carl
Carl
As long as you have the correct disc/drum, you're ok.
http://www.speedwaymotors.com/Disc-D...alve,9878.html
