New cam no tune am i ok to drive it pre tune?
Like the title says i got done doing a cam swap from stock to a pretty irratic 240/240 600 lift cam on a 110 lsa. Im in the process of moving and was just wondering if im ok to drive the car or if i risk hurting anything? The weather has also been really cold lately... like 30's to 40's. Thanks in advance guys
EDIT: i would also like to mention i didnt change out the injectors from when the car was previously tuned
Since you changed injectors you need to input proper injector table info in the tune. Your cam is also petty big and that can be a danger of going lean in upper rpms and too rich below that.
Bottom line, get it tuned ASAP
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Aside from starting it and watching it idle I would be ultra cautious if I had to drive it. Maybe nothing more than foot off the brake or clutch disengaged idle and limit to a few city blocks. Probably runs kind of iffy right now anyway. But you will either lean out or just wash down the cylinder walls and going from stock to that size it is really risky. Bottom line is spend the 40-75$ to have it towed where you are getting it tuned.
I wouldnt say no tune if you had it tuned previously though. But also assume that its no where near where it needs to be.
i put pretty big cam in my car (6 speed) car..with ls2 injecters and an ls6 intake on it all in one and drove it that weekend all the way to columbus to my tuner...which is a 4 hr drive..and the car ran justtttt fine..just depends how far you gotta drive it.
correct ^^^^ if you have to drive to get it tuned do that..like what i did..i wasn't out driving it to work or anything..just don't beat on it. that should be enough said by everyone ha
