Computer Tune after Cam?
Old 12-31-2010, 01:14 PM
Paul 75 L82's Avatar
Default Computer Tune after Cam?
I would like to understand what changes might be made with the computer tune. I understand that most will include a dyno pull so you will know you hp and tq. I don't really need those numbers I just want to know what adjustments the tuner will make. Can you do the same thing with a Hand held device?
Old 12-31-2010, 02:11 PM
KevinR's Avatar
You will probably have a lot better luck asking this in the PCM Diagnostics & Tuning section
Old 12-31-2010, 02:18 PM
StormesRacing001's Avatar
Honestly, you should probably get it tuned professionally. Give Dan at Masport in Boca a call. He should be able to answer any of your questions.
Old 12-31-2010, 03:21 PM
brian_rs/ss's Avatar
adjustments are most times made with hp tuners, it's software that you have to purchase to install on a cumputer. and trust me tuning is best left to the pro's. it's extremely easy to screw up.
Old 12-31-2010, 03:47 PM
2000_SS's Avatar
you have to re-adjust start-up, idle, drivability, and WOT parameters which require a wideband O2 sensor and some sort of EFI tuning software like HP Tuners or EFI Live.
handheld tuners (like Hypertech, Diablosport, etc...) only have predetermined tunes in them for very general modifications like headers/exhaust, cold air intake, lower thermostat, taller/shorter tires, new gears, etc....
Things like heads/cam swaps, or even simply stepping up to a much better flowing intake manifold, require adjusting your primary VE table, main spark, startup airflow, etc.....HP Tuners has nearly 200 parameters that it can adjust, EFI Live has even more still, not all of which require adjustment, but a lot of important things do need done that a handheld tuner cannot do. A chassis dyno isn't necessary, it's just a tool that makes the job a LOT easier by simulating driving conditions and allows you to see exact rwhp/rwtq.
Thanks for the info, I don't want to screw anything up.
Old 12-31-2010, 05:33 PM
Like I said, Check with Masport Speed Shop. Dan is a great tuner and he actually wrote a book on how to tune the LS1. Plus he is right in Palm Beach County!!!
Old 12-31-2010, 07:24 PM
garygnu's Avatar
if you are using a stock gm TB make sure it is clean,ICS ,TPS.
Quick Reply: Computer Tune after Cam?
