What kind of Oil do you guys use?
Im assuming some of these guys run thicker oil because they have non stock bottom ends and form what most builders have told me when you build an LT1 you open up clearance slightly as the clearances are slightly tight from the factory for a high rpm engine.
So when you open up clearances you run a thicker oil.
