help
help
hi guys
i have a problem
i have z06 model 2002 i installed a Trick Flow Package from summit.com
heads and Camshaft and i buy diamond Pistons -2 with rods
the heads is 215 , 64 cc .
the cam 228 ,230 , 585 ,585 lop 112
but in dyno 422 hp 377 torque
i dont see any power in the car
but it should give me in dyno 470 hp at least.
plz help guys
i have a problem
plz help guys
i but kooks Headers with X-Pipe with Corsa exhausts , Vararam Air Intake , Crank Pulley slp , for the tune in the graf in 6.200 r p m its go dawn but now i dont see problem
in the graf its good .
normal dyno
normal dyno
You should have milled the heads down to 59cc chambers, ran you a set of .040 cometics and got your compression up across the board. Take advantage of them -2cc piston reliefs.
the trick flow top end kit from summit is crank hp.what tranny?if a auto what stall?what is your air fuel ratio like?what injectors did you use?what was your timing?what was the air temp when it was dynoed?do a compression check ...and many more questions.
i just got back from watching a hc car with underdrive pully and ls6 intake and longtubes put down 447 i think 470 is asking alot might be possible but i dont think with that cam
