need more fuel
need more fuel
I own a 04' C5 ZO6 but I've only had it for 11 months. And I'm still learning the fuel system. My question is about my options for increasing fuel without dropping the tank. The car makes roughly 440ish to the tire so I'm pretty sure I need to upgrade in the fueling system to spray a little.
Other than the typical Casper/Racetronics hotwire with the KB BAP is there any other ways to increase the fuel without dropping the damn tank?? I've been reading about the famous Bosch 044 and its potential. I have lots of ideas but I'd like to hear you guys thoughts.
O, and I've talked to all the professionals and they all want me to drop $1200-1700 bucks on there kits plus the price to drop the tank/suspention/tranny/rearend. Seems crazy for a 150 -200 shot. I've considered a stand alone but the rest of the system is hidden and that would blow all the hard work that went into that.
BTW, I'm only planning on spraying about 5 times a month. Because I only go to the track once or twice a month. The rest of the time it will be on the tank pump only. The more I type the more it sounds like the hotwire/BAP is the way to go.
But I still want opinions and facts on this.
Thanks....
Thanks....
You need a different pump...no other options when you're spraying 150 on top of 440rwhp. You're just going to kick yourself in the *** running lean because you cut corners. Dont know much about corvettes but on the fbodys you can cut an access panel to get to the tank. Might want to check into that.
Yeah, I've thought about the cutting the floor deal but its a 26K mint ZO6. But its still not ruled out. I'm not sure if I misunderstood you or you me but I do understand that the factory walbro 255 is not enough. Thats why I started the thread, I'm looking for alternatives to adding fuel with out going into the tank. Thanks.. Like another pump....external...
LS1TECH Sponsor
Unfortunately there are few options...
Vette pumps seem to fail frequently with a boost-a-pump. I've had tons of guys call me looking for solutions after their pump failed.
The 044 is a good pump, but not easily applicable to the C5/C6 style Vette installation.
Yes you can run an external, but still takes a lot of extra work to make it function properly... & you are drilling holes in your fuel tank.
Bite the bullet & do it correctly... you have a nice car. Cutting corners can end up costing you problems, either with failures or engine damage in the long run. Actually about 20% of the people I deal with buy their fuel systems after they break their engine or spend money on cheap fixes that do not work.
