trunion upgrade proplem
Old 01-11-2011, 03:40 PM
Turd Gen Guy
1nasty86's Avatar
Default trunion upgrade proplem
ok before the upgrade i never had any kind of noise from my engine. now since my rocker upgrade i can rev the motor a few times and it makes a tapping sound, like a rocker tap. it doesnt do it every time just maybe 1 out of 5 or 6 revs. ive checked side clearance between every rocker 3 times to see if they are not too loose which they are not! if anything there a bit on the tight side. next thing came to mind was now ptv clearance. i run a 230/238 .600/.604 112+2 cam with 317's milled to a 64cc chamber. any help would be great! im pulling my hair out guys!
Old 01-11-2011, 04:00 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I would check the clearance on the cam. In order to get 317 heads down to a 64cc chamber you would have to mill ~.050" off. That is a pretty decent amount and the cam you have has some duration to it, so I think it would be worth checking. Although, with a clearance issue it is something that is usually not imtermittent. Are the lifters in the motor new? If not, you might also check the lifters for any problems.
Old 01-11-2011, 04:08 PM
Turd Gen Guy
1nasty86's Avatar
they are ls7 lifters with around 3000 miles on them. they were removed once from the motor and left in a bag until i needed them a month later. my pushrods are 7.350 if that makes any difference. the motor made NO noise like this before my rocker arm upgrade. same cam, lifters, heads, etc. just with stock rockers
Old 01-11-2011, 04:36 PM
SOMbitch's Avatar
Retorque the rockers..
Old 01-11-2011, 05:13 PM
JPH
JPH's Avatar
Sounds like a lifter issue?
Old 01-11-2011, 05:18 PM
Turd Gen Guy
1nasty86's Avatar
i just retorqued them today actually! but ill check them in the morning just to be 100% sure they are tight after running. i have lock tite on the exhaust bolts and thread seal on the intake bolts because they run into my intake runner.
again there was no noise untill after my trunion upgrade. i ran the car for about a month with the same heads, lifters, and camshaft. before doing the upgrade. no noise
Old 01-11-2011, 05:22 PM
JPH
JPH's Avatar
Sounds like you have one or a couple that bleed down to rapidly. This does happen to certain lifters, because you have taken the rockers on/off, preloading/unpreloading the lifter.
Old 01-11-2011, 05:35 PM
Turd Gen Guy
1nasty86's Avatar
any fix for this? besides replacing them? ive knowticed that it has gotten better since i took some play out of the bearings on the rockers and let the motor run. but there is one that still does it.
Old 01-11-2011, 05:52 PM
JPH
JPH's Avatar
What do you mean as far as play? Up/down movement or side/side on the rocker?
Old 01-11-2011, 05:56 PM
Turd Gen Guy
1nasty86's Avatar
side to side. i could move them a fair amount and they would make the same noise when i would move them, there is now no side movement between the bearing and retaining clip. and it still makes the noise. just NOTHING as much. the engine sounds normal idleing but when i crack the throttle every now and them i hear the tap.
Old 01-11-2011, 06:30 PM
Old School Heavy
speedtigger's Avatar
I would suggest you take the rockers off and see if the bearings rotate completely silky smooth. When you rotate the shaft in the rocker needs to be completely smooth without catches or roughness.
If it is not completely smooth, have a look at this thread:
https://ls1tech.com/forums/generatio...l-problem.html
Old 01-11-2011, 06:36 PM
Turd Gen Guy
1nasty86's Avatar
i actually read that earlier. but i dont see how that would affect my motor making a tapping sound intermetately?? glad you found that out though!
Old 01-11-2011, 09:33 PM
Turd Gen Guy
1nasty86's Avatar
Forgot I also plugged up my oiling towers under my valley cover when I installed the rockers. But imo that wouldnt affect anything
Old 01-12-2011, 01:51 PM
JPH
JPH's Avatar
I see. You should always have a tad bit of side/side movement, but there is a point where it can be to excessive. I would start their and see if something in that rocker upgrade that was not performed properly or the trunion is not correct?
Old 01-12-2011, 02:58 PM
Turd Gen Guy
1nasty86's Avatar
I looked at it again today. Didnt tighten the valve cover down as much and it didnt do it. So im unsure what it could be. Maybe it was hitting the valve cover and I cant see it. But ill keep checking it.
Old 01-12-2011, 03:44 PM
chrisfrost's Avatar
tighten the valve covers back down to at least where they were when the noise would show up and put you're hand/fingers on the valve cover where the noise is and if it's hitting the cover you will be able to feel it . good luck
Old 01-12-2011, 03:45 PM
Turd Gen Guy
1nasty86's Avatar
ive never heard of stock rockers hitting though, thats whats keeping me from believing thats the proplem. they are stock 03 5.3 valve covers.
Old 01-12-2011, 04:49 PM
JPH
JPH's Avatar
Alright, pm me or post your combo on recently what you have changed or done to cause/warrant this new noise issue! Pushrod length change or anything else you have done at the same time you were upgrading rockers?
Old 01-12-2011, 05:22 PM
Turd Gen Guy
1nasty86's Avatar
The only thing I did was upgraded the rockers, installed a fast 102, and plugged my oiling towers under my intake. My setup is a stock shortblock ls2, t.e.a. Ported 317's stage 3 shaved to a 64cc chamber with 2.08/1.60 valves, the cam is stated in the first post 230/238 .600/.604 112+2, pushrods are 7.350, head gaskets are cometic .51. The cam was spec'd by pat g himself so I trust him.
Old 01-12-2011, 07:32 PM
JPH
JPH's Avatar
Start with unplugging the oiling towers and go from there. (whatever those are, haven't heard that term yet)
Quick Reply: trunion upgrade proplem
