bbc-tr6060
Old 01-12-2011, 08:58 AM
mrbeautie's Avatar
Default bbc-tr6060
What do I need to do to adapt a BBC to a 2010 Camaro TR6060? Or same trans to old SBC?
Old 01-12-2011, 10:23 AM
85MikeTPI's Avatar
Alot.... The Camaro tr6060 has an integrated bellhousing, remote shifter, flanged driveshaft attachment, etc. You can try to get a Magnum front plate, but then you're dealing with a conversion bellhousing (quicktime) or a spacer.
Unless you've got deep pockets or a friendly trans/machineshop you might want to pass on that project and just get a Magnum to start with.
My $0.02
Old 01-12-2011, 01:03 PM
Jeremy@RPMTransmissions's Avatar
Like Mike said, the magnum is a much beter option. As of right now I am not aware of Quicktime making a bellhousing for anything using the 2010 Camaro TR6060 with a Magnum front plate. The camaro TR6060 and the Magnum use a different length input shaft. The Magnum also has the propper style shifter too. The 2010 camaro has a divorces shifter assembly that would make a swap kindof a pain in the rear.
Old 01-12-2011, 09:43 PM
mrbeautie's Avatar
Thanks guys for your replies, got options that might work. How about the same tr6060 2010 camaro transmission hooked up to a 2002 LS3? What would I need? Also would be installing in a 63 Vette, so could I get the shifter to remain in the stock position?
Old 01-13-2011, 06:22 AM
85MikeTPI's Avatar
https://ls1tech.com/forums/new-ls1-o...56-tranny.html
Posts #14 and #20 have pictures that might be helpful.
It will bolt right up to an LS3 and flywheel/clutch setup, it's the shifter and driveshaft that would be a challenge..
Quick Reply: bbc-tr6060
