exhaust
Old 01-12-2011, 10:13 PM
why_so_serious's Avatar
Default exhaust
what does everyone have? im thinkin the cheap route and just deleting the resinators anyone else have that done?
Old 01-12-2011, 10:20 PM
91_rs-teal's Avatar
have done res delete, its a bit better than stock. just makes it a lil bit rappy. gives it a lil tone.... for cheap id say go with that
Old 01-12-2011, 10:26 PM
i think i will until i can get a full system is there a step by step guide on here somewhere?
Old 01-12-2011, 10:43 PM
AlabamaGuy's Avatar
First off, welcome.
Searching can find you a ton of information much quicker than waiting on people to stumble in and offer opinions. You can find a much larger variety of information by doing a search.
To answer your question, I would start with a catless DP and do a custom 3" setup from there back.
Old 01-13-2011, 01:24 AM
ImpSS07's Avatar
just get a cutout.
Old 01-13-2011, 05:08 AM
BigBlackBoxChevy's Avatar
I have deleted the resonator and put a cut out in it's place. Can't imagine having anything quieter than that on an LS4
Old 01-13-2011, 08:24 AM
SSCoop's Avatar
i took the resonators and the mufflers off
Old 01-13-2011, 02:22 PM
BackNBlackSS's Avatar
Anybody on here running Magnaflow cat-back without that resonator? ?
Old 01-13-2011, 03:30 PM
LS1 Racing's Avatar
I know this has been discussed before, but did those of you who deleted the resonater notice ANY seat-of-the-pants increase in power?
I ask now because I'm getting the catless DP installed while the trans work is being finished, and it would be very easy for the shop to swap out the resonator. But I don't want to do it if there's no performance benefit. It's just not worth the few extra $$ to me.
Old 01-13-2011, 04:33 PM
EmersonHart13's Avatar
No power increase. The resonator is a straight through design so there is no way removing one could add power.
Old 01-13-2011, 04:37 PM
i like the tone it has i just want it louder and i was thinking about straight pipes i just want it to sound good
Old 01-13-2011, 04:43 PM
LS1Tech Sponsor
06MonteSS's Avatar
yeah, what Emerson said... there are no gains at all power-wise... it's already a straight-through pipe, just has packing around it to keep it quieter in the cabin...
you won't gain anything by removing it, except more cabin noise...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 01-13-2011, 05:22 PM
LS1 Racing's Avatar
Thank you! If it doesn't build power, it's not worth doing!
I have straight pipes now, though I'm getting Magnaflows welded in today because of the catless dp that's also going in.
Having lived with straight pipes for the better part of the past year-and-a-half, I can tell you that it takes some getting used-to inside. You get a serious drone at highway speeds, and it can really rattle our cheap interiors. That said, it sounds freaking AWESOME when you jump on it, and that's why my wife is sad that we're getting mufflers!
Do you still have a resonator with your FMs?
Old 01-13-2011, 07:33 PM
AlabamaGuy's Avatar
Straight pipes sound like ****. We have a truck cam and combined with out chassis it sounds TERRIBLE at anything but WOT. I can say with confidence that I have had more exhaust setups on an LS4 than any other owner and I can say I have FINALLY found something that works. It doesn't sound like an F body with longtubes but it doesn't sound like a farm truck. It's loud, rattles the interior and I've had enough of it. The ladies hate it and the rattles annoy me to death. I'm going to run it on out the back to cure the drone and resonance from the turndown under the back seat and if nothing major changes I will finally be done.
I write all this so you won't make the same mistakes I did. The rasp with a chambered muffler or straight pipes is going to sound like complete ****.
Old 01-13-2011, 07:59 PM
1BAD06MCSS's Avatar
a little dynomat in the trunk and around the spare tire well will help out the rattle noises. I had this problem and fixed it and my trunk rattle due to my sub. I no longer have any rattles inside or outside the car. I bought a complete trunk kit from my car audio salesman for $140.
Old 01-13-2011, 08:00 PM
1BAD06MCSS's Avatar
AlabamaGuy, what exhaust setup do you have right now?
Old 01-13-2011, 08:21 PM
what he said
Old 01-13-2011, 09:22 PM
AlabamaGuy's Avatar
Headers, 3" mandrel, Dynomax Race Bullet, Spintech Pro Street, Turndown.
Old 01-14-2011, 07:25 AM
Red06SS's Avatar
Magnaflow Cat back.
Old 01-14-2011, 08:18 AM
DieselPump's Avatar
I run headers, to a metalic solo performance high flow cat, solo resonator, 3" stainless mandrel to 2.5" y-split into solo performance mach mufflers and dual 4" ss tips.
Flows great, and sounds awesome.
