Is the LY-6 the only 6.0 that came wit hL-92's in the trucks?
Well that about sums it up, are there any other 6.0 motors that came with L-92's ?
Also what pistons and what is the stock compression of a LY-6 ?
Any other info on LY-6's would be greatly appreciated.
Sorry... but the vvt/afm parts are inside the engine. I think you would be better off purchasing a LQ4 OR LQ9 and adding a set of L92/LS3 heads and L76/LS3 intake kit to save you some money and head aches along the way.
Its cheaper to buy a LY6 than typical LQ4s and MOST LQ9s
Remember those have 58 tooth reluctors and are VVT, so there is going to be more costly things need done to it to swap over into a LS FBODY.
I just purchase two 04 Escalade LQ9's with 67k & 71k miles for $550 each, one used set of L92's heads $425, new set of LS3 $675 and two take-off LS3 intake,injectors,rails for $275 each. So thats $1200-1400 for basically for the same engine, but with a much better intake and has a 24 tooth reluctor wheel.
BTW, these two engines will be installed in a 67 Buick Skylark and 98 TA.
if the engines have a 58x reluctor wheel, you'll need a 58x to 24x converter from Lingenfelter. It runs about $250. Thats all u need really, other than just switching over sensors, brackets, etc.
James
James
^^ Totally forgot about that. lol
Texas Speed and alot of other bigger sponsors on here sells the stuff you need. They offer a whole gen 4 (LS2) conversion kit. It comes with a front timing cover with cam sensor, valley cover, timing chain, lifter trays, and the harness for the knock sensors and the cam sensor and etc. It's all there for about $300.
