e 85 flex fuel conversion
I currently have a 383 lt-1 with a LTCC LS-1 coil pack conversion. Im switching to a ls1 ecu as well as adding a turbo and was interested in running e85 as a flex fuel. I plan on running it all the time but would like to be able to have the ability to switch back and forth in case I end up out of my area and have no access to E85. I just bought a 76mm turbo and need to completely replace my fuel system so I figure its a good time to hit it all at once. Im assuming ill need a flex fuel ecu and fuel sensor.
Has anyone else had luck with a system like this or am i asking for trouble?
I'm not really familiar with the flex-fuel PCMs, except that they require feedback from a few sensors that you probably don't have on your car. For my current build I purchased a dual-flash PCM. I plan to use that as my solution.
Frost sells them. I think he may be the only one. new dual flash pcms run 2 seperate tunes one pcm
BTW the search button can answer many questions
