Weighed my wheels today....
Front 15x3.5 Weld Draglite, 165r tire, 1 spacer, 1 centercap, 5 lug nuts: 26lbs
Rear 15x8 Weld Draglite, 27x10.5 tire, 1 spacer, 1 centercap, 5 lug nuts: 35lbs
Stock 16" painted TA rim, 245/50 tire, 5 lug nuts: 45lbs
Total weight savings over stock wheels: 58lbs
Weight off the front alone: 38lbs
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
and 58 lbs of rotating weight is more than 58lbs of stationary weight, that could be close to a tenth, plus the reduced tread contact on the front tires helps on less resistance as well.... Good to know, maybe I'll one day weigh my Nova's wheels...
Derek
Derek
Convo Pro wheel & tire weights:
15x7.5 w/ 28x10 ET Drag 35 lbs.
15x10 w/ 28x11 ET Street 33 lbs.
The ET streets are a little worn. That might account for the less weight. ALl the rubber from the tire is still stick inside my wheel wells.
Originally Posted by AL SS590 M6
My Bogart front 3.5" with 165r tires are 25 lbs. each.
