Head swap parts list
You could do it with head bolts and head gaskets only if you wanted. I would pick up a set of water pump gaskets as well. Makes it a little less messy on draining the coolant out. The valve cover gaskets, intake gaskets and exhaust manifold gaskets are all reuseable. Let me know if you need anything. We stock it all!
Jon
Jon
With that cam, you want the compression. A 6.0L head is going to have a 72cc chamber and drop the compression. You can go with some LS6 heads if you like since they start with a smaller 64cc chamber and can probably be milled a touch if you like. There is some more power to be made with the LS6 heads due to more airflow over the 5.3L head. Just depends on how much power you are chasing.
Jon
Jon
