Picked up a used short block, what to look for before assembling?
Old 01-18-2011, 01:03 AM
Black94Z28's Avatar
Default Picked up a used short block, what to look for before assembling?
Picked up a LT1 shortblock minus the cam, cylinder walls look ok, no scratches or anything. What should I look for to make sure this is ok before I build her up.
Dont plan on machining the engine if not needed, ran when pulled, just want to check it over and reassemble.
Old 01-18-2011, 01:08 AM
BlackBird87's Avatar
check all the bearings
Old 01-18-2011, 01:37 AM
RamAir95TA's Avatar
While you're there I would certainly upgrade the OEM rod bolts to some ARP 7/16".
Old 01-18-2011, 08:38 AM
quik95lt1's Avatar
if you know the motor was in good running condition there should be no need to pull it apart.......if you want to you can pull a rod cap and a main just to see what the bearings look like but if it was properly maintained it should be fine.......ARP rod bolts are a decent idea but......
Joe how are you going to put 7/16" bolts in a rod designed for a 3/8" stud without machining the rod????
Old 01-18-2011, 09:10 AM
am_muscl's Avatar
it was my shortblock. The cam bearings are going to need replacing but other than that it was in fine running condition.
Old 01-18-2011, 09:37 AM
Village Troll
SS RRR's Avatar
Why is that?
Old 01-18-2011, 09:47 AM
quik95lt1's Avatar
im assuming he probably tore them up when he yanked the cam out???.......and if you do need to do cam bearings how do u plan on getting them in and out while the RA is in the block?????
Old 01-18-2011, 11:58 AM
96lt1m6's Avatar
Ain't happening!
Pull motor apart, replace rings,bearings,cam bearings,add ARP bolts resize big end of rods,new timing chain,oil pump w/white spring.............
Old 01-18-2011, 12:48 PM
AChotrod's Avatar
Im with him^^^
Old 01-18-2011, 01:43 PM
ScrapSilicon's Avatar
Default I was going to suggest checking cam bearings but
Originally Posted by 96lt1m6
Ain't happening!
Originally Posted by AChotrod
Im with him^^^
ditto
Old 01-18-2011, 03:28 PM
RamAir95TA's Avatar
Ain't happening!
That's how. I didn't respond entirely because posting from my phone is painful.
Old 01-18-2011, 03:30 PM
quik95lt1's Avatar
^ oh thats makes sense then i was like damn come on joe u know betta than that lol
Old 01-18-2011, 04:00 PM
96lt1m6's Avatar
Joe I feel your pain......been using my droid to log in since my laptop crashed! PITA 2x
Old 01-18-2011, 04:03 PM
am_muscl's Avatar
well the motor has 130k miles on it and before I did the cam swap, I went too long without changing the oil n i think it fucked up the cam bearings. I think Mike will probably tear it down anyways but I just figured I'd put in that it was mine and what I knew.
Old 01-18-2011, 04:06 PM
96lt1m6's Avatar
Old 01-18-2011, 06:28 PM
Black94Z28's Avatar
I may just end up redoing the entire engine if the bearings are shot, ill inspect it and if so, I mind as well build up a nice 355 to throw in the 94 when the current engine craps out. Heres a pic of the engine sitting in the garage...
Thinking if I do rebuild the engine, going with forged pistons, rods checked and ARP bolts installed, 847 or similar cam for the short block.
Old 01-19-2011, 07:42 AM
quik95lt1's Avatar
after hearing this^.........yea tear it down with out a question........time for a rebuild!!
Old 01-19-2011, 11:43 AM
96lt1m6's Avatar
Especially since this shortblock is sitting as a backup....... revert back to my first post.
Old 01-19-2011, 10:20 PM
Village Troll
SS RRR's Avatar
So did you divulge this information prior to the block being sold or just now?
Old 01-20-2011, 11:49 AM
am_muscl's Avatar
it was never "sold", and mike knew all that prior. i'm not that kinda ******* that would sell something shitty like that without him knowing
Quick Reply: Picked up a used short block, what to look for before assembling?
