C5 motor mounts work on CTS-V?
I would like to know as well, but it looks like it will have to wait until I actually get the motor out.
I have a set of C5 pfadt mounts that "look" like they will work. One difference I can already visually see is that you would have to relocate the alignment pin in order for it to work on a V, if the dimensions are even correct.
Depends. If they are longer it might work but since the vette has the batwing oil pan the whole thing is probably lower in the car than the V.
