What size amp for JL 10W3v3 sub?
Either amp would work just fine. Depends on how loud you are used to having a stereo. I have never had JL products before but I think the amps provide the same power @1 ohm as they do 4 ohm so it wont matter if you use one of the JL slash amps you listed above.
Thanks man. I saw the slash amp and its $599! I wanted to keep the system on a budget. If I get their cheaper 500/1, would that not work? Sorry man I know nothing about audio lol. Trying to learn.
Heres the JL Amp:
http://www.crutchfield.com/p_136JX50...tp=35834&avf=N
It was between that setup, or going Alpine with these 2:
http://www.crutchfield.com/p_500MRPM....html?tp=35834
http://www.crutchfield.com/s_500SWR1...3D.html?tp=111
Heres the JL Amp:
Kleeborp the Moderator™
I have that exact Alpine setup in my Camaro - it hits pretty decent, and I can turn it up loud enough that I can't stand it, which passes my test. It replaced an MB Quart 10" with an MTX amp feeding it (something in the 300-ish watt range), and I was very pleased with the change.
