Tire Pressure Monitors
As long as whomever removes them doesn't break or damage them, they will work fine.
There are different styles, but here is one style and how to remove/reuse them:
Source: 2011 gs tpms location - Corvette Forum
EDIT: Make sure you remember what sensor goes where. If you move the sensor to a different tire location, they will all need to be relearned.
Search this forum for the relearning procedure (I posted it not too long ago).
When I put the aftermarket wheels on my car, I reused the ones that came with the car. One of them did break from removal so I had to go to the stealer to get a replacement since it was the weekend. Be careful when removing them.
Since you are reusing the factory sensors, pick up the TPMS servicing kits from Napa which are a few bucks a piece. Its cheap insurance down the road in case one of the seals has a leak.
They're reusable and should last ten (10) years (battery life).
OP- I re-used the factory ones when I switched to my ASA AR1's.
