Still cant quickshift
Awhile back, I installed a stg 3 monster kit which included, clutch, flywheel, pilot, and slave. After proper break-in, I took the car to the track where I proceded to break the rearend and driveshaft due to a miss shift into 2nd.. I swapped rear and DS. Tranny never shifted the same. There was some resistance getting it into gear. And if the car sits for over say 8hrs, It will not go into gear. I read alot about the Tick so I picked it up. It helped a bit, but still not able to shift at high rpms. Please help
Full inspection for leaks at the master, slave and line is step one.
Drill mod needs done if it has not been already.
Bleeding: the jmd method: https://ls1tech.com/forums/13837919-post3.html
Did you check air gap and shim the slave accordingly?
The monster didnt come with any shims, as for the air gap, I'm not familiar with that so I'll have to do some research.
Also when the aftermarket clutch disk gets heavier, shifts will be a bit slower because it takes a bit longer for the heavier disk to slow (inertia) when the syncros are trying to match speeds of gears in the tranny between shifts.
My Spec 3+ is nearly 2 pounds heavier than the stock disk and it slightly impacted the speed and ease of shifts whether shifting slow or fast. Also the blocker rings have to work harder to match speeds between shifts with the heavier disk so if the blockers are not working correctly, shifting will be slower.
