STARTING ALL OVER WITH A LT1 BLOCK.. WHAT 1st?
Old 01-23-2011, 04:27 PM
MAROBOY_TRAV's Avatar
JUST PULLED A LT1 BLOCK OUT OF A 1994 RAGG TOP z28.. STRIPPED IT ALL DOWN NOW I PLAN TO BUILD IT BACK UP FROM SCRATCH.. WHAT WOULD BE THE FIRST FEW ITEMS TO GET FOR IT?
I was thinking bottem end kit?
Old 01-23-2011, 04:39 PM
Sof86's Avatar
I think maybe you should tell us what your goals are with the engine/car.
Old 01-23-2011, 04:42 PM
k0261886's Avatar
There is no need to yell at us
Old 01-23-2011, 04:43 PM
WS Sick's Avatar
Well get the block looked over so you can order youre reciprocating assembly.
1badzee's Avatar
What exactly are your goals? Budget?
Old 01-23-2011, 06:13 PM
Goals are to keep tha original block size (no boring) looking to get about 380-400 to tha tires..
Not yelling just so use to typing in caps. Sry
Old 01-23-2011, 06:41 PM
1badzee's Avatar
Look into Lloyd Elliot or Advanced Induction for top-end (heads/cam/intake) packages. You will meet your goal with them.
www.advancedinduction.com
and
http://elliottsportworks.com/
Old 01-23-2011, 08:04 PM
96capricemgr's Avatar
Just get a junkyard shortblock then, go and put cheap aftermarket rotating assembly in there and it will be a step backwards.
Old 01-23-2011, 09:05 PM
defaultexistence's Avatar
Nitrous
Old 01-23-2011, 11:55 PM
LilJayV10's Avatar
1. Decide what your budget/goals are.
2. Take the engine to the machine shop to check it out, see if needs bored.
3. Start ordering parts.
Quick Reply: STARTING ALL OVER WITH A LT1 BLOCK.. WHAT 1st?
