Hooker headers question
Old 01-24-2011, 10:09 AM
VinR1's Avatar
Default Hooker headers question
I found a good used set for practically nothing but without a y-pipe. They have the 3-bolt flange after the collectors
if I cut the flanges off, is there an off-the-shelf y-pipe that will fit these?
I dont know the part# but they're the off-road version and have the #1 primary that comes off
TIA
Old 01-24-2011, 10:57 AM
carlos64030's Avatar
http://www.flp-motorsports.com/produ...r-headers.aspx
Old 01-25-2011, 07:22 PM
ss.slp.ls1's Avatar
It really shouldn't be that big of an issue. You could put the headers on and get an off the shelf y-pipe to an exhaust shop and either have them weld on some flanges to the y-pipe and bolt it together, or you could have them cut off the flanges and use a y-pipe like the one linked. If the y-pipe doesn't match perfectly after cutting off the flanges, it should be little work to an experience exhaust welder to get it to work.
Old 01-25-2011, 07:39 PM
onephatZ28's Avatar
i went to a local shop and had one made it was only like $80.00 installed
Old 01-25-2011, 09:08 PM
Blackbirdws6's Avatar
Mufflex Y-pipe will fit right up to supercomps and is huge.
Old 01-25-2011, 11:35 PM
hitmanws6's Avatar
or why not just buy a hooker y?
Old 01-26-2011, 08:20 AM
VinR1's Avatar
bleh, he sold 'em before I even had a chance to ask for pics
I've just heard the flange ends up scraping and not holding a good seal so I was wondering what y-pipe would slip on if I just cut the flanges off
Old 01-26-2011, 11:08 AM
Bersaglieri's Avatar
I never had a problem with flanges dragging, perhaps if you've lower the car a bit. I threw a set on my beater car for cheap, just bought a Summit X-pipe kit and me and a buddy welded her up. I think I have $350 in my exhaust from head to exit.
-Dustin-
Old 01-26-2011, 03:15 PM
Oh I dunno, maybe because its much larger than the hooker y-pipe...
Old 05-03-2013, 01:29 PM
Wallj's Avatar
TIA
I know this is an old thread but I just bought these same headers, used, with no y pipe. So I have the same question about cutting the flanges off and using another y pipe like pacsetter, etc. any help would be great!
Old 05-03-2013, 02:35 PM
Jason94z's Avatar
like the other guy said mufflex y pipe bolts on no problems
I have the 3" collector Y pipe to 4" single
Old 05-03-2013, 05:03 PM
Village Troll
SS RRR's Avatar
Mandrel bent?
Quick Reply: Hooker headers question
