help!! dash vents not working..
ok guys, long and CRAZY story short..
3 days ago i had a locksmith guy come to my car to replace my ignition cylinder and make a new key..
he takes off steering wheel, airbag etc. and fixes everything..
well today i go to turn on my heat and notice only the floor vents are working!! none of the dash vents are blowing at all..
did a search on the site and found that it could be a vacuum leak?? already checked behind the intake and everthings plugged in..any help would be greatly appreciated thanks
no..whichever setting i put on it will only blows on my feet and not the dash vents:/
when i say "dash" vents im meaning the 5 vents going across..the defog vent actually works when i put it on however..
Yea, im fairly certain the blend doors and vent selection are vacuum controlled, so i would check behind your HVAC controls and on the Ducting itself and make sure none of those vacuum lines popped off, i dont know how with removing the steering wheel this would happen, but damn them gremlins
I know you said you checked behind the intake.....
BUT.......my tranny guy was working on my car a couple months ago and knocked the small vacuum line off the back of the intake, its the one that runs to the small "T" fitting by the PCM.
I also had only my foot vents and defroster....nothing else would work. My small vacuum line was off behind the intake.
Check again.
Check again.
