lq4 year and wiring ?
Old 01-27-2011, 05:14 AM
mrabel's Avatar
Default lq4 year and wiring ?
First off, Hello to all. There is alot of great info here! I have read hours of posts and don't have a clear answer. My ? is I can get a good deal on a real low mile 04 lq4, no harness or computer.Want to go dbw. What year and wiring harness do I get? also like to keep it fairly budget friendly.Can I use and mod a f body harness and computer or do I have to have a truck harness and computer? any help is most appreciated.
Old 01-27-2011, 07:35 AM
garys 68's Avatar
Modifying a 99-02 f body for DBW is probably not cost effective.
By far, the easiest solution would be to buy a 5.3 or 6.0 03-05 harness, ecu, TAC, and pedal.
Old 01-27-2011, 07:48 AM
LS88FoxBody's Avatar
Agreed 03-04 Computer , and harness.
PM me , for some harness help , and questions.
Old 01-27-2011, 09:05 AM
typhoon1015's Avatar
You should be able to get a harness and computer, etc no problem with the engine also. I would stick to gettting the same truck harness/ecu tac, pedal combo of the truck if your planning dbw.
Depending on what your looking for i have the tac and pedal assembly for a 04 lq4 i plan on not using.
Old 01-27-2011, 02:32 PM
mrabel's Avatar
Thanks for the quick responses. I did'nt want to make a long dragged out post, I forgot to mention my friend will give me the f body harness and computer. If I go dbc will this run that motor with some mods to the harness?
Old 01-27-2011, 08:49 PM
Pocket's Avatar
Going from DBC to DBW and reverse isnt that difficult. You need a handful of connectors, TAC module, and pedal
Yes, the Fbody harness will run the engine directly when using a DBC TB. It can also be converted
Old 01-27-2011, 08:50 PM
LXinMS's Avatar
Check your PM, OP.
Old 01-28-2011, 07:06 PM
jwcarguy's Avatar
I have a DBW TB from a 03' 5.3L does that work the same?
Old 01-29-2011, 07:55 PM
ge_forcez22's Avatar
you might have found it already, but www.lt1swap.com is amazing!
Old 01-30-2011, 08:54 AM
mrabel's Avatar
I did find this. thanks for all the help.
