5.3 with ls1 intake
Old 01-27-2011, 01:56 PM
greasemonkeychef's Avatar
Default 5.3 with ls1 intake
just a quick question for those who have done a conversion. The coolant crossover/bypass on the 5.3 wont let the intake sit down. Do most guys replace this or bend it or?????
Old 01-27-2011, 03:53 PM
garys 68's Avatar
bend it
Old 01-27-2011, 04:00 PM
You have done this before gary?
Old 01-27-2011, 04:19 PM
bronx_peanut's Avatar
I bent mine out of the way works great. Good luck!
Old 01-27-2011, 04:23 PM
garys 68's Avatar
Yep, no issue at all.
btw, there's a Peoria, AZ???????
Sweet thxs for the heads up guys.
Old 01-27-2011, 04:59 PM
biggeazy-e's Avatar
Peoria, AZ is north of Glendale, southeast of Surprise, AZ
Old 01-28-2011, 07:08 PM
jwcarguy's Avatar
A friend bent his overin his swap also with no issues
Old 01-28-2011, 09:11 PM
PPI Typhoon's Avatar
I bent mine out of the way for the LS6 intake on an LQ4. Seems to fit quite nicely.
Old 01-29-2011, 07:54 PM
ge_forcez22's Avatar
I bought the plugs for the rear, and just the front 2 connect. was maybe $45 used.
Old 02-01-2011, 11:29 AM
exboatracer's Avatar
I've got the same problem,so I need to ask this (maybe dumb)question. How do you bend the upper coolant fitting without destroying it to clearance the throttle body bellcrank? Thanks.
Old 02-01-2011, 01:45 PM
I ended up buying a used LS1 collant bypass just cause it wasnt a bad price. I was thinking about it and have head guys dont have a overheat issue if you block off the rears. So in theory you could cut the pipes and tweek a bit and connect them at the fron and rear with rubber hose. Or rubber at front and weld the the rears closed.
Old 02-01-2011, 10:21 PM
Thanks for your reply,I think I'll try to bend it somehow,maybe some heat and some tapping and see what happens.
Old 02-02-2011, 11:54 AM
Josh40601's Avatar
can anyone post up a picture of the coolant crossover bent? Also, how did you bend it?
Old 05-05-2011, 08:48 AM
s10jake's Avatar
R y'all using the truck heads? An the ls1 ports r a different shape is this a problem?
Old 05-05-2011, 08:49 AM
46Coupe's Avatar
I bent mine. I put a small screwdriver in the pipe so it wouldn't kink and gently moved it into position.
Quick Reply: 5.3 with ls1 intake
