msd crank trigger
msd crank trigger
i've done a little bit of searching and haven't had much luck. can anyone give me the rundown on what i need to get rid of the opti signal and use the msd crank trigger as my signal or tell me where to find the info? i know the opti also controls injector firing. I wan't to do this because i'll be over 7k and previous opti issues. It would give piece of mind. I have the msd 6a but i don't know if it is compatible with this setup. Any help?? thanks
i used a cheapy stamped spectre chrome unit, shaved all the unnecessary bends off of it so it was flat, then epoxied it to the opti cap. I normally wouldn't rig something like that, but really didn't feel like spending more than 10 bucks for something hidden under the water pump and ****.
I see, good point. I am batch firing now with the dfi. I am interested in going sequential. The best route would be to ditch opti and put a standard distributer in for cam signal and a crank trigger up front.
What is your option?
Will doing that and running a crank trigger get rid of the "weak link" of the opti? If you are using the opti as just a distributor does it make it safer?
Why not drill the intake a run a crab style distributor? That will give cam signal and run crank trigger for crank signal. Or run a dual sync distributor?
or you could just run the opti as a distributor? and instead of paying for machining, a dual sync distributor (which have their own problems as well), and welding the opti hole you could run my setup inside the opti which should have zero reliability issues. Look for more info of this running on my motor in a few weeks.
