Keep my H/C/I Forged 346 or go with 408cid ?
Hi guyz
I have 02 Camaro SS M6/3.42 with forged forged piston/rods, PRC 5.3, EPS baby cam and FAST 92/92
They car made great power N/A ~ 428RWHP/410RWTQ and 600+ with 150 shot
I enjoyed how the car drives and idle stealthy like stock, never plan to go to track only using it on the streets and race from a roll
I like N2O but the fact says that I cannot go bigger shot on my LS1 block,
and I wanna a 500+ RWHP and near 500 RWTQ in my N/A power with small to mild cam. Planning for 250-300 shot
6.0 bare iron block is in my garage, so 408cid will be my goal but I read a lot threads about weight and how it will effect the performance of the car !! .. I'm not doing drag racing.. only 50+ MPH roll and spray .. so I don't think the weight will be a problem in my situation ..
I'm not from US, and down here in my country Supras and Skylines with 750-900 RWHP are alot .. I know they are dyno queens but they are really fast at long distance
If I go with 408cid here will be the list
- Callies/Diamond Rotating assembly from TSP ( 11:1 ~ 11:4 CR )
- WCCH L92 Heads
- Ported FAST 102 w/ Direct Port for N2O Outlet
- Custom EPS cam
- Fully ARP Studs & Bolts
What do you think guys ?
- WCCH L92 Heads
- Custom EPS cam
sounds like what Im gonna build minus the eps cam, Sounds like a winner to me!
If you're doing roll racing are you sure you don't want a SC or turbo?
I would take nitrous over a blower for rolls, turbo would be best though.
I would go 416 l92, save some weight, already have the l92 heads to port, more cubes.. but since you already have the block it would make sense to do 408.
+1 on LS3 416 or 427
But if budget is a problem go with 408 and try to avoid spining due to weight transfer
Why dont you spray more than a 150 shot if you have a forged motor?
2. the purpose of the swap to 408cid is to have more power N/A
Thanks guys for you comments
So guys 408cid is waste of time/money ?? Is it really that the 100lb make that difference in street car ????
The 408ci looks good but avoid the l92 hype. I removed mine for trickflow 235 and gained 20hp and 15tq under the curve. Same peak power but my car went faster at the track. The l92 heads out flowed the tfs according to flow data sheets. Have the block set up for a 300 shot and have fun.
go with the 408 build I have a iron truck block 402 its stood up to all i could throw at it so far been hitting it with a 200 shot off the plate setup.Im in the process now of putting a direct port nitrious outtlet has some killer ones.On the hit these nitrious cars leave like a bat at hell
I'd say go for the 408 in iron, 100 lbs from a roll is not as bad as from standing start.
As for heads, the WCCH L92 heads are great but will require you to shell out a bunch for yet another intake. Given you already have a pretty good intake, you may want to stick with cathedral heads - AFR, TFS or MAST may be your best option. Add up all the parts before making your decisions.
i vote keep the forged 5.7. you were talking about doing a direct port, id do it to what you have.
then when that gets old...then upgrade.
i would think a forged 347 with a 2-300 shot would be plenty....maybe because thats what im working on.
i just looked up some part numbers, and the same part number for front coil springs were listed between a 94 Z28 and a 02 Z28
