CC503 or GM846, will it pass emissions with a tune??
Old 01-29-2011, 09:45 PM
LVZ2881's Avatar
Default CC503 or GM846, will it pass emissions with a tune??
THe LT1 cam guide sticky says they will with tuning. I was hoping to hear from a few who are running either of them and have passed emissions. I will be running LT's, with a catted y pipe and a TSP Rumbler cat back. stock head and bottom end.
I'm trying to decide between the 2.
Old 01-29-2011, 09:47 PM
hitmanws6's Avatar
Id go a different route for emissions. Id call LE or AI and look into one of their emissions cams
Old 01-29-2011, 09:53 PM
myltwon's Avatar
AFIK both are emissions passable with a good tune. might get tired of that exhaust when you get a cam though, I know I disliked my loudmouth once I got headers, hated it when I got a cam. though the fact that you are running a cat might help.
Old 01-29-2011, 09:58 PM
AChotrod's Avatar
Depends how they test
Old 01-29-2011, 10:00 PM
LVZ2881's Avatar
sniffer test, both idle and and @ 2500 rpm
Old 01-29-2011, 10:07 PM
LVZ2881's Avatar
I'm also considering the Lloyd Elliot 224/230 .573/.568 cam. His website says its the largest emissions frinedly cam he recommends. and its bigger lift wise than either of the 2 i listed
Old 01-30-2011, 12:57 AM
Spartan7's Avatar
I have a 222/230 112 LSA, specced by Lloyd. Barely passed CA emissions with a mail order tune, probably would have done better with a good dyno tune.
Old 01-30-2011, 09:07 AM
95mysticta's Avatar
Lloyd spec'd me his 223/230 .565/.565 112lsa cam for my emissions build. Up here in Toronto, Canada its a little more forgiving but im not sure how strict it is where you are. Ive heard the cc503 passing but good luck passing a cc306 just not going to happen. When i was talking to AI they spec'd me a 222/230 112lsa cam. Bottom line is if your on a budget and buying used get the 503 otherwise opt for a custom grind by le or ai and stay under the 230 duration and you should be fine. Both of the custom grinds will make roughly 15rwhp more then the cc503. Another key part is cats you will need and i suggest the fullsize cats vs spun or bullet cats which dont have alot of minerals in them to help make the cam pass the sniffer.
Old 01-30-2011, 01:02 PM
96lt1m6's Avatar
There has been many 503 owners pass emissions its all in the tune! The cc306 could pass only if it was in an obdII car where they just check for see light key on engine off........
Old 02-06-2011, 03:52 PM
ryanisfast's Avatar
my car is a 97, I have all the dtc's regarding emissions disabled through a tune that solomon gave me. Will I pass the test? all they do is hook up the obd2 scanner I think. I don't think they'll sniff it. BTW, my cars mods are in sig.
edit: Also I have no check engine lights on at all.
Old 02-06-2011, 04:56 PM
93v8clone's Avatar
my car is a 503 car with longtubes and no cats , i pass n y emmisions and there just as rough as cali,s
Old 02-06-2011, 04:59 PM
Spartan7's Avatar
I doubt that. You'd never pass here with no cats.
Old 02-07-2011, 09:45 PM
93v8clone's Avatar
im a inspector dude . im talkin our emmisions testing lol
Old 02-07-2011, 10:04 PM
Wicked94Z's Avatar
cc306 has passed, with fresh cats, manifolds, 4.11 gears. I believe it took two tries and some tweaks by the tuner. This was like 5 years ago local though, can't remember much else.
Old 02-08-2011, 07:39 AM
quik95lt1's Avatar
my 222/230 .555/.565 112+4 cam in my 355 passed
Old 02-08-2011, 11:15 AM
joelster's Avatar
Im in NY as well. Your car should have failed the visual for obvious reasons. Since it's OBDI is does not get hooked to the NYSDMV computer to get run through. The OP's car is OBDII and he gets a sniffer test. Having the tune cleared for codes, simply won't throw codes which would get it to pass if that is all they were looking for. In his case they are also going to sniff test the car. No getting around that. Maybe toss some 1.5 rockers on it if you have some laying around that will work to slightly decrease the overlap, get the tune dialed, and hope for the best. I'm not sure what effect raising or lowering the idle speed would have on the test. Maybe someone else could chime in?
Quick Reply: CC503 or GM846, will it pass emissions with a tune??
