General Maintenance & Repairs - Emergency Brake
Maximus0066
02-04-2011, 03:36 PM
I was wondering if anyone knew how to tighten up the emergency brake. I have to pull mine all the way up and it seems like it only holds on the last click or whatever. Thanks in advance
Ryan
wssix99
02-05-2011, 08:00 AM
Ryan
This is a common issue after rotors are changed out. The bore can be slightly different and the brake needs to be adjusted for that. The first link below has generic info on the system and the second link has a diagram of the components in one of the threads:
- http://www.pbr.com.au/products/original/parkbrakes.shtml
- http://www.ls1tech.com/forums/suspension-brakes/845856-parking-brake-assembly.html
This thread has a procedure for doing the adjustment. Its a total PITA and needs to be done twice at each wheel, with the tire and disk brake caliper off:
http://www.ls1tech.com/forums/suspension-brakes/862055-emergency-brake-needs-tightening.html
The write up in the thread above isn't the greatest, so please feel free to post back if it isn't clear.
LS6427
02-05-2011, 12:55 PM
Mine is getting a little out of wack too. Good post..........
Too bad that old myth about going in reverse about 10mph and hitting the brakes real hard to make them work again doesn't really work........ lol
wssix99
02-05-2011, 04:50 PM
Too bad that old myth about going in reverse about 10mph and hitting the brakes real hard to make them work again doesn't really work........ lol.
It does with drum brakes that are designed to wear. :) That's how they adjust as the pads wear down. Since the parking brake pads don't wear down, (assuming you aren't drifting with the car) they have a different type of mechanism that doesn't self-adjust.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
