Conversions & Hybrids - Any1 use Molex XRC bulkhead system
Jimbo1367
02-05-2011, 10:05 AM
I seen this in a SuperChevy mag recently.
www.superchevy.com/technical/interior/wiring_gauges/sucp_1103_project_unfair_1969_chevy_camaro_tractio n_control_system_install/photo_07.html
It looks simular to DSE's setup.
www.detroitspeed.com/projects/dse-chevyII/dse-chevyII-pg-1.html
Jimbo1367
02-05-2011, 10:07 AM
DSE pics # 68 & 69. (6 rows up from the bottom; 2nd and 3rd pics from the left.)
Gray86hatch
02-05-2011, 01:36 PM
We use them on aircraft every day. very nice and expensive.
Tim
leon phelps
02-05-2011, 02:13 PM
Have put together thousands of different Molex connectors. They are known for simplifying installations and helping with wire management.
Your hard drive power connector is even a molex connector.
Like Tim says, expensive and work well.
joejbal
02-05-2011, 02:34 PM
Those are typical of military connectors, like the others have said. Tyco makes a similar product, but is plastic, CPC, circular plastic connector.
gofastwclass
02-05-2011, 02:45 PM
I thought about it because I saw the Detroit Speed guys using them years ago - until I realized how much they cost. I may revisit them on a different build, but the projects I've done so far I couldn't justify the budget. :( ...but man do they look sharp! :D
gofastwclass
02-05-2011, 02:51 PM
To eliminate potential confusion... we're talking about these:
http://www.detroitspeed.com/projects/dse-chevyII/data/images1/dse-chevyii-122l.jpg
http://www.detroitspeed.com/projects/dse-chevyII/data/images1/dse-chevyii-121l.jpg
Jimbo1367
02-06-2011, 08:24 AM
Thanks Gofirstclass!!!
what is "expensive" ??? ball park figure?
thanks
01cherryreds10
02-06-2011, 03:15 PM
I knew I shouldn't have opened this thread
Pop N Wood
02-06-2011, 04:09 PM
We use those on our airborne radars.
McMaster Carr sells those connectors, prices don't look too outrageous. The 13 amp per connector rating would prevent them from being used for everything on a car. Probably need to mix these with just a couple higher amp rated connectors.
MMC's web site seems to have plenty of other options.
http://www.mcmaster.com/#pin-and-socket-connectors/=ax4jdi
Waytek has a bunch of different options too
http://order.waytekwire.com/scategory2/m50/320/550/
Ooh. Just found this one
http://www.americanautowire.com/catalogs/AAW_sections/AAW10_BulkheadsDisconnectsGroundingAccess.pdf
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
