fbody accessories
not exactly. similar though
That diagram is from GM? Wow, not even close
The PS pump is different from F-body to GTO/CTS-V in being a detached reservoir. Most everything else looks the same but cross reference the bracket PNs at the dealership before going with it
Knowing GM, its likely similar to the B-body vs F-body LT1 accessories. Look identical but nothing interchanges directly
The CTS-V and F-Body accessories are not interxhangeable. You need the LS3 damper and water pump for the former. The CTS-V belt is 22mm closer to the engine than the F-Body.
