post pass opti issues
Old 02-07-2011, 10:59 AM
ALEXZ28's Avatar
Default post pass opti issues
my car is having idling issues, it smoking and smells like fuel. car wont hold an idle and i have to keep giving it gas to keep the car running, im wanting to compare others issues with mine to see if maybe it could be the opti.
post up some opti passed issues please
Old 02-07-2011, 11:08 AM
l 95 Trans Am l's Avatar
My last opti issue wasn't actually the opti BUT, it was that my opti connector was destroyed and corroded, causing it to cut out connection when it got hot.
Old 02-07-2011, 11:10 AM
Are all your plug wires ok? Check the spark plugs, sometimes the ceramic cracks in them and you never know till you take them out. This one time I washed my car and I'm guessing I got something wet in the ignition and it was stumbling like yours at an idle, and it smelled like gas.
Old 02-07-2011, 11:19 AM
ALEXZ28's Avatar
the car wouldnt fire, i changed all the plugs now i got the car to fire but smokes like fuel when i give it gas and wont idle. all the wires are new 8mm msd.
Old 02-07-2011, 11:42 AM
wickedbusa's Avatar
My car would randomly not start. Even let me stranded on the freeway once. I would let the car sit for a few weeks and it would start up again.
Just replaced the opti this weekend and car fired up right away. Drove around for a while, turned the car on and off while hot, then again after getting back home after letting it cool down and no more issues. Wires still looked good, my old opti looked pretty trashed though.
Old 02-07-2011, 12:30 PM
qc97z's Avatar
If you're having to give it throttle to keep it alive, what about MAF/MAP sensor issues?
Old 02-07-2011, 03:26 PM
camar0corey's Avatar
When my first opti went out it wouldn't rev above 3k rpms, and to even get there it ran choppy as hell. Would barely hold an idle. Managed to limp it back home the mile or so, pretty ugly. When I had a second Opti failure it randomly misfired.
Both opti failures were after the car sat un-driven for over a month.
Old 02-07-2011, 03:31 PM
defaultexistence's Avatar
Every time my opti goes bad my car transforms into a robot and destroys ****
Old 02-07-2011, 07:38 PM
ALEXZ28's Avatar
sounds about close to what mines doing, it barely idles and sounds like *** when i give it gas to keep it running. it idles right at 200 then shuts off, and smokes, im wondering if the reason for the smoke could be bc its getting fuel but not enough spark.
Old 02-07-2011, 08:39 PM
lethal bird's Avatar
My car did the exact same thing when my opti died.
Old 02-07-2011, 09:13 PM
Could it maybe be his o2 sensors?
Old 02-07-2011, 10:49 PM
ALEXZ28's Avatar
i figured it was opti, smokes bc its getting fuel not enough spark. it wouldnt be 02s bc the car by passes the 02s in wot.
Quick Reply: post pass opti issues
