New Guy- Want Cam/ Heads input
Old 02-07-2011, 06:11 PM
LS Desert Ranger's Avatar
Exclamation New Guy- Want Cam/ Heads input
I have a stock 2000 5.3L. Today I picked up some (241) LS1 Heads w/ New PRC Double Springs, a New Vengeance Racing VRX4 Cam (228/230, .588/.592 112 LSA) and New Comp Cams Magnum pushrods for a good deal. How do you guys think this combination will work out? Im gonna get the comp dyno tuned at Cunningham motorsports in Temecula. The motor is going in a desert race truck w/ manual valve body TH400 and 9" w/ 4.56 and 35" tires. Also now have 5.3L 706 heads and cam w/ low miles for sale if anybody is interested, sounds like the heads are a good compression upgrade.
Old 02-07-2011, 06:22 PM
Darkman's Avatar
I am confused by your description of the heads you've got. LS6 heads are 243s, not 241s, which are LS1 heads. Which do you have?
Old 02-07-2011, 06:28 PM
ok i got LS1 heads then i guess. they say 241.
Old 02-07-2011, 06:34 PM
Nacho SS's Avatar
I would get the 241s milled and ported and go with a bigger cam because that th400 and 9inch are gonna eat some power.
Old 02-07-2011, 07:00 PM
i was told to get them milled at least 40 thou. to bring my CR up and still be able to run on pump gas. I was also told that cam would probably be maximum for the 5.3L. Im looking for mostly low to midrange power since this is a desert truck and wont be absolutely pinned for long periods of time. Do you guys agree with the things i was told? Any other suggestions?
Old 02-07-2011, 08:05 PM
Whiteaw57's Avatar
i actually agree. that cam is plenty for that 5.3. snd the heads shouldnt be terrible. I would have them milled and any port work you can afford will be helpful and give you some more power.
Old 02-07-2011, 09:26 PM
is my cam considered big or small? will it still give me decent low end torque? and what stall torque converter should be used with it? I also heard that any shop worth a **** nowadays does CNC porting and that **** is big bucks.
https://www.vengeancerd.com/ecart/pr...7D.592-112-LSA
Old 02-07-2011, 09:54 PM
Whiteaw57's Avatar
In an LS1 it would be a good mid range cam probably make around 380-390 rwhp with supporting mods. I have the 224/230 114lsa in my 98 Z and it was dead even with my buddies 233/239 114lsa that dynoed 403rwhp. in a 5.3 however it will act like a slightly bigger cam. Id expect to make around 360rw(if it was in an fbody the 9 inch will eat up some and so will the tranny) or so with the 112 lsa. but I dont think you have a bad setup, the cam should make decent torque as well and the 4.56 gears are a plus
Old 02-07-2011, 10:07 PM
lemons12's Avatar
I would have got the 5.3s ported..
That cam will make excellent power under the curve and come In low, you won't have to turn 6500+rpms to see it shine.
Old 02-07-2011, 10:29 PM
would it have been better to get the 5.3 heads ported rather than swap to LS1 heads? I was told the LS1 heads were a better head since they flowed a lot more air compared to the stock 5.3s and that they were a good upgrade for cheap.
Old 02-08-2011, 12:10 PM
lemons12's Avatar
The 5.3 are a nice bump in compression. Ported they flow good.. They would make nice midrange and tq down low.
Old 02-08-2011, 03:51 PM
how much is typical for a good to decent porting job? i heard its pretty expensive.
Old 02-08-2011, 03:54 PM
lemons12's Avatar
Depends on the porter.. anywhere from a few hundred up to a grand. Call some sponsors.
Old 02-12-2011, 11:54 AM
If i get the 241 heads milled down to bring the CC back up, would they then be similar to the 5.3L heads?
Old 02-12-2011, 12:03 PM
lemons12's Avatar
Any ported/milled head is going to perform decent. if you have those, use them.
Old 02-12-2011, 12:26 PM
do you know how much to mill down the 241 heads to match the 706 heads compression?
Old 02-12-2011, 12:34 PM
01ssreda4's Avatar
I wouldn't go crazy milling them. 30 should be good. They have bigger valves then the 5.3 heads but bigger chambers as well. Makes sense as they came on a larger engine. You may lose a tad bit of compression in exchange for better flow. It will be fine. I would choose a 3200-4k converter depending on how aggressive you are trying to be.
Old 02-12-2011, 12:43 PM
do you think .40 or .45 would be too much?
Old 02-12-2011, 01:59 PM
01ssreda4's Avatar
I have heard that going to 40 could cause intake alignment issues. That being said, there still is no reason to run on the ragged edge. I dont know what ptv clearance would be but I like to play it a little on the safe side. A good thing to do would be to measure your ptv, then use that to help you decide how much to mill.
Old 02-12-2011, 02:22 PM
how do you measure ptv clearance properly?
