Power glide with turbo 6.0?
Old 02-07-2011, 06:34 PM
john_stout's Avatar
Default Power glide with turbo 6.0?
Wanting to know if any one has ran a power glide in a turbo f body? Car should weigh around 3500. The power glide I have does have a brake, just don't know how well the 1.74 low gear is gonna work in a 3500 # car
Thanks
Old 02-07-2011, 08:43 PM
Restricted User
Vortech Converters's Avatar
You'll hate a glide at that weight. Stick with a 3 speed if this is gonna be a race car or real hot street car.
Old 02-07-2011, 10:13 PM
AutoRoc's Avatar
Disagree... it depends on how much power you want to make I think. If you want to make 500rwhp, I would do a 3 speed.
If you want to make 700+ rwhp, a powerglide is the way to roll. Easier to control the power. With a 3 speed, you launch the car and instantly have to shift. A 3 speed might be a tenth quicker at the track but only assuming you have 100% traction. I have also heard that the long first gear loads the turbo harder resulting in quicker acceleration. True? A glide is much more fun on the street too. 0-80 in low gear and 80-160 in high gear. Getting the converter right is the most important part. Do not cheap out on the converter. Goodluck!
Old 02-07-2011, 11:53 PM
john_stout's Avatar
It might make 700hp. It's a forged 370 with ported 317s and twin t70s and will have nitrous set up on a pressure switch to turn off at 4psi of boost. On high boost i will run 15psi
Old 02-07-2011, 11:59 PM
john_stout's Avatar
And the main reason I'm looking at running the p guide is cuz it's brand new with a brake and bunch of goodies in it for 650
Old 02-08-2011, 07:06 AM
Restricted User
Hey roc, if you still had your car you whould have got whipped by ridings and his 3spdr and got called out on MT. Hahahaha. You probably know who this is now. Lol
Old 02-08-2011, 07:24 AM
AutoRoc's Avatar
Vortech? I thought it was Vortex converters. I still have my car, I'm just switching to a turbo 4.2 inline 6 w/ 4L60E. Haha always ******* on my Vigilante/Joels combo.. ill be ringing you for the $175 special!!! I probably would have had my turd in the 7's with your 3 speed. The world may never know.
John, if you already got a good deal on the trans, try it. I would switch to a 30 spline input shaft before buying a converter. That way you can switch to a 3 speed if you don't like the 2 spd and the converter will fit both.15 psi on a head/cam 370 with twin 70's and some spray will make a ton of power. You will love the glide. The cam and power peaks will dictate stall speed but something around 4500 rpm will get you moving in a hurry.
Old 02-08-2011, 09:20 AM
Restricted User
Roc,
Give me a ring tonight (anytime). I have a few idea's!
Old 02-08-2011, 09:26 AM
cgslow77's Avatar
turbos and glides go together like p and v
Old 02-08-2011, 05:21 PM
john_stout's Avatar
Alright thanks guys
Old 02-20-2011, 01:57 PM
getsum27's Avatar
hahaha
Quick Reply: Power glide with turbo 6.0?
