What # for 2 bar map
I've been trying to locate the correct part numbers for the 2bar map. I found a couple of links, but want to make sure that these will work on my 02 Camaro as a plug and play (factory plug)
GM part # 12580698 or AC Delco part # 213-163
http://www.hptuners.com/forum/showthread.php?p=27772
https://ls1tech.com/forums/pcm-diagn...re-sensor.html
Again, just verifying that these will work in the stock harness.
Thanks.
Thanks.
Thanks.
