Rear Mount turbo
STS is not very popular on the GTO forums. Search around over there for any info you need in regards to FI as options they have similar setups to the V1. The piping rust on cars that are not even daily driven as it is simply coated mild steel. Most cannot even sell their kit when taken off due to these issues.
shameless plug for you brothers epically awesome, jizz in my pants turbo build. haha. its a good thing to do, because it is one amazing build. i hope if i ever make it to Houston, you guys will show me the Vs. which may be in 6ish months, because my brother could be moving down there.
it has been done...
agreed lol
I'd put them here, actually just an inch or two more to the rear of the car to help the intake clear the front cradle. I made some custom intakes, that follow the charge pipes pictured below and lead to a cone filter behind the bumper fog lights. Its not the prettiest, but I'll get some pictures soon.
I just finished installing an Alky Control meth kit, should have it back on the dyno next week. Looking for 600+ to the tires!
I've put about 3k miles on the setup, and the charge pipes still look practically new with only an inch long scratch on the driver side pipe. Ground clearance is a non issue.
yeah my brother and I were talking about that. How they did really good work on the manifolds, but then they use crap turbo's and cheap steel....
Well a little bit, but also just saying, why drop the money on a single turbo rear mount taht will have lag, and really doesn't look that great when you can pay a bit more (if any) and have 2 turbo's and a BAD *** set up and no lag... Come on, kinda not even a decision is it?
it has been done...
agreed lol
it has been done...
agreed lol
I'd agree for someone brake torquing such as the starting line on a drag strip, but on the street when you punch it, I'm sure it would be felt.
Don't get me wrong, I love turbos ... I just like them like GulfM3's where the plumbing is measured in inches not yards.
How do you figure? Are you saying that the distance between the exhaust ports to the turbo plus the distance from the turbo to the TB is irrelevant?
Are the rear mounted turbos smaller so the spool time is quicker?
I figure to there would be some kind of turbo lag due to to the
length of the the tube and the time needed to build pressure in it?
Also is there any issues with all the connections and leaks?
