Looking to make more power out of my ls1 suggestions please.
Old 02-11-2011, 11:29 AM
ballinboyz44's Avatar
Default Looking to make more power out of my ls1 suggestions please.
I have a 04 pontiac gto with a few mods. I have longtube kooks headers, kooks hi flow cats, magnaflow exhaust, aem cold air, hp tuners tune, comp cam. I was wondering what I should do next to make more power. I dynoed at 422 whp
Old 02-11-2011, 11:33 AM
atrain59's Avatar
Heads or my favorite Nitrous
Old 02-11-2011, 11:35 AM
would heads effect mess with the reliability? i drive her daily for now till i get something else, also what would i need for nitrous is my motor ready for that?
Old 02-11-2011, 02:16 PM
SOMbitch's Avatar
Depending on the heads you get you could see anywhere from 20-45ish gains.
With a GOOD tune most will tell you up to a 150 hit is safe but a few have gotten away with a little more...
Old 02-11-2011, 07:46 PM
Detoxx03's Avatar
Heads or if you want a significant amount some nitrous. If you have a good tuner I would do both.
Old 02-11-2011, 11:20 PM
mike c.'s Avatar
I would add some trick flow or afr heads to the mix. 40hp should be gained. n.o.s is great,but more stress if you hit it all the time and the bottle runs out. I don't even spray a full bottle a year.
Old 02-11-2011, 11:50 PM
180ls1's Avatar
what cam, like what are the specs? I would say that a good set of heads and a fast intake would be a good idea i assume the cam is pretty large to be making that power in an ls1.
Old 02-13-2011, 10:15 PM
im not sure but i can find out and ill post it on here, he said it has the highest lift i should go without getting heads
Quick Reply: Looking to make more power out of my ls1 suggestions please.
