Fabbing up a mechanical oil pressure gauge.
I actually have already fabbed up a permanent oil pressure gauge under the hood but I have a question.
I used a 24" stainless braided brake hose to connect the block fitting to the gauge. It allows me to route the gauge up to the windshield so I can watch the oil pressure while driving when the need arises.
Is there any issue with using a brake hose? Can it be relied on to no provide any issue down the road? Is there something more desirable to use?
generally just copper/aluminum tubing like the solid part of your brake lines, flexable break line still has rubber inside i assume? so the rubber can get ate up over time. just a guess though
Village Troll
Sounds like you may have had fittings that were not flared or the flares did not mate right. I learned recently when doing a brake line that there is flared and inverted flares and it can be a puzzle geting things linked togther correctly.
I have the mechanical gauge tee'd in right where the OEM electric sender is. I would call them just basic flare fittings but it took a while to find the right ones while ensuring the flares were right to resist leaking. To this day, they have never leaked a drop and the gauge works great. I am just concerned about that brake hose. I even fabbed a nice bracket to mount the gauge right above the left strut mounting bolts.
Searching the net, I have found a couple other folks that have used a brake hose but I have yet to read where the hose caused a problem.
I'm assuming you're using an autometer type gauge. If you are this is what I like. You can get them in varying lengths, and I know they're pricey, but I prefer these to the nylon line, or copper tubing that autometer uses, and it's a lot more durable than straight hydraulic hose. Either way. You could also just by the fittings from autometer and then get -4 nylon braid which will actually save you some weight compared to the steel braid.
This is just what I've always used more for peace of mind. You'll never pop that line unless you hit some crazy oil pressures.
ANd I just re-read you original post. I believe the brake lines are constructed the same way, so you should be fine using that line. Sorry for the confusion.
Village Troll
