Ok, not sure what engine I have now
Old 02-15-2011, 05:01 PM
mentiroso's Avatar
Default Ok, not sure what engine I have now
Ok I thought I had a LS1 with the LS2 heads (243 cast # on them). Today I got the first oil change and the filter for the LS1 does not work. The oil change place tried one (#wp48?) and it worked. Guy said those are like 06 and up engine filters. Anyone have any clue what engine I would have based on that? Sorry there isnt more to go on. When I first joined someone told me where to find cast numbers but I never could find them so if someone can point that out again I can look again, maybe a picture would help?
Anyway just trying to figure out what I am working with here.
Old 02-15-2011, 05:18 PM
babbage1109's Avatar
how many liters of oil were used....what car is it...mods all that crap
Old 02-15-2011, 05:22 PM
mentiroso's Avatar
Sorry, forgot my sig was gone
1999 Trans-Am
6 quarts were used (Mobil1)
SLP Lid, headers, x pipe, straight pipes into dual bullet mufflers
Old 02-15-2011, 05:39 PM
probably a lq4 or 9. how long have you had the car? previous owner ever mention it?
Old 02-15-2011, 05:44 PM
mentiroso's Avatar
I bought the car from a dealer in South Florida. The salesman told me the previous owner had put $5000 into the engine (complete swap) but he did not know details. I assumed the salesman was lying but I did not care. The price I paid for the car was fine even if it had the stock LS1, I just wanted a fun daily driver.
Old 02-15-2011, 05:46 PM
6 liters is not stock lol idk if there are any identification numbers on it. might have to check around
Old 02-15-2011, 05:51 PM
mentiroso's Avatar
Yea if anyone could tell me an easy way to spot what engine I have for sure I would appreciate it. Like I mentioned, I know the heads are the LS2 heads because of the 243 stamp. Anything else I can easily spot without having to lift the car?
Old 02-15-2011, 06:27 PM
jim ravencraft's Avatar
Hi,
please find attached numbers courtesy of will handzel. He authored many books and is well versed on ls engines. I hope this helps you! have a blessed day..jim
Attached Thumbnails Ok, not sure what engine I have now-engine-numbers-courtesy-handzel-001.jpg
Old 02-15-2011, 06:31 PM
mentiroso's Avatar
Excellent list thank you for posting! Where would these numbers be located though?
coolmanvette75's Avatar
most likely its a 6.0 or some sort (ls2, lq9, lq4)
Old 02-15-2011, 06:35 PM
mentiroso's Avatar
Would the LQ4 or 9 use the 243 heads?
Old 02-15-2011, 06:58 PM
im pretty sure their stock heads are 317. people put on the 243 heads to bump up the compression
Old 02-15-2011, 07:12 PM
Hi,
the casting number is located on the engine block at rear drivers side bank. You can't miss it. This is true for all third and fourth generation...... Have a blessed day. Jim
Old 02-15-2011, 07:30 PM
mentiroso's Avatar
Ok will have to check that out tomorrow, little too dark outside and I do not have a flashlight. Thanks for all the info guys, big help!
Old 02-15-2011, 07:34 PM
mentiroso's Avatar
Originally Posted by jim ravencraft
Hi,
Well one more question, is that on the side of block towards the tire or on the back towards the firewall?
Old 02-15-2011, 07:54 PM
ovaboost's Avatar
left side back by firewall and what does it have for intake manifold? i bet its an ls2 is the block iron cast or is it aluminum thats another way to tell if its lq or ls motor
Old 02-15-2011, 07:58 PM
mentiroso's Avatar
Not sure what it is, I should probably know the difference but sadly I dont. Here is a pic I took when I first got it.
http://mobiletechspecialist.com/firebird/100_2163.JPG
If that helps?
Old 02-15-2011, 08:02 PM
ovaboost's Avatar
the iron cast will be black dark color and the aluminum will be silver in color. That manifold looks like an ls1 or ls6.. ls2 manifold have the 90mm tb and 4 bolts that bolt the tb on
Old 02-15-2011, 08:05 PM
TheBlackPlague's Avatar
lq9 -lq4 = cast iron block. quick check with a magnet.
Old 02-15-2011, 08:40 PM
mentiroso's Avatar
Ok, magnet did not stick. I stuck it right in front of where the headers attach, seemed to be the easiest spot to hit in the dark, checked it and all around it, did not stick to anything.
Quick Reply: Ok, not sure what engine I have now
