Would my front tires rub?
Old 02-18-2011, 05:50 PM
2001-CamaroSS-LS1's Avatar
Default Would my front tires rub?
im putting 275/40/18 all around on my SS....as the title says..would the front rub?
Old 02-18-2011, 05:56 PM
babbage1109's Avatar
No! Just as long as backspacing is good
Old 02-18-2011, 06:28 PM
wabmorgan's Avatar
My 285/35R18 rub just a little in the front on the plastic fender liner.... but it has never caused a problem and only rubs with the wheel turned to where it hit the liner.
Old 02-19-2011, 07:37 PM
anyone else???
Old 02-20-2011, 03:44 AM
Undertow74's Avatar
i cant speak much on the 18's but i have 275/35/17 on the front and am lowered and no ribbing here....
Old 02-20-2011, 11:22 AM
KingCdogg's Avatar
Shouldn't rub
Old 02-20-2011, 12:20 PM
There are autocross guys that run 17x11s on all four corners so I mean. Anything is possible
Old 02-20-2011, 01:16 PM
gocartone's Avatar
275/35/18 is almost the same size diameter as the stock tires are(25.6" vs 25.7"), I would go with those instead. A 275/40/18 is an inch taller than the stock tires, so the chance of rubbing would be a lot higher. I think they should still fit, but I would go with the stock height myself.
Quick Reply: Would my front tires rub?
