Final ratio with th400 in 3rd gear
Old 02-18-2011, 11:51 PM
mr_biscuitz's Avatar
Default Final ratio with th400 in 3rd gear
Whats the actual ratio in 3rd gear with a th400? Ive been told they are 1.1 and been told there not. Thanks for any input you guys have....
mr_biscuitz is offline
Old 02-19-2011, 12:03 AM
Predator T/A's Avatar
Predator T/A is offline
Old 02-19-2011, 12:10 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by Predator T/A
1.1...
Z28/2002 is offline
Old 02-19-2011, 07:40 AM
Moderator
Vince B's Avatar
Any three speed gm trans the 3rd gear ratio is 1:1. In a power glide which is a two speed is 1:1. In a gm 4 speed over drive unit 3rd gear is 1:1. The only trans that does not have a 1:1 ratio I believe is the 6 speed auto.
Vince B is offline
Old 02-19-2011, 09:25 AM
thanks
Old 02-19-2011, 10:20 AM
XpEdItIoUs's Avatar
any non overdrive trans will end in 1.1
XpEdItIoUs is offline
Old 11-22-2013, 08:09 AM
wade Cearley's Avatar
Default Buzzbomb
I have a TH400 that was behind a 4.3 V6. I now run a 350 V8 and found the final ratio of the TH400 and found that the V6's used a lower ratio. I have 2:73 gears and it drives like a 4:11. Mileage is about 11 MPG.
wade Cearley is offline
Old 11-22-2013, 09:22 AM
c6matt's Avatar
but you have a non locking converter, so the engine RPM will seem like the ratio isn't 1:1 if you do the math.....I just wonder if thats where the confusion could be coming from..
c6matt is offline
Old 11-30-2013, 04:11 PM
big wally 55's Avatar
The 3rd gear ratio is still 1-1 , I have never seen a 4.3 with a 400 behind it from the factory . Don't think it ever happened ! What is this combo in ?
big wally 55 is offline
Old 11-30-2013, 04:18 PM
Are you sure the trans is shifting into 3rd gear ??
Old 12-02-2017, 09:14 PM
daniel dorminey's Avatar
Cool
I have a 4.3l/400 in my 1985 chevy c10 custom deluxe
daniel dorminey is offline
Old 12-11-2017, 02:34 AM
AutomagicLS1's Avatar
it's always 1.00. I have a 2nd gear leave th400 in my car and its 1.48 "first gear" and 2nd gear "third gear"/high gear is 1.00
AutomagicLS1 is offline
Old 12-11-2017, 07:26 AM
AnotherWs6's Avatar
You sure? th400's never came from the factory bolted to a 4.3. Just a taaad bit of overkill. Though I've certainly been wrong before.
AnotherWs6 is offline
Old 12-11-2017, 09:23 PM
clinebarger's Avatar
Not technically a TH400, They were TH375's.....Which are based on the TH400 but with a 27 spline output & fewer frictions. By the mid 80's TH350C production had ceased but GM still offered a 3 speed auto & was probably cheaper than a 700R4.
clinebarger is offline
Old 12-20-2017, 08:11 PM
Moderator
mrvedit's Avatar
Thanks for the info Clinebarger.
On your note I'm closing this thread which really should never have been re-started.
mrvedit is online now
Quick Reply: Final ratio with th400 in 3rd gear
