Swap into 84 Chevy 4x4 ?'s
Old 02-21-2011, 03:09 PM
stryker1320's Avatar
Default Swap into 84 Chevy 4x4 ?'s
I have recently acquired a 1984 3/4 ton Chevy 4x4 and all it needs is a good engine. And since I have a couple extra LT1's laying around, I figured I would throw one in there. The truck has a good transmission (350) and transfer case already, and I have already started working on the fuel system. I already have the extra ecm (A4) and wiring harness but My question is, what all will I need to do to get it to work with the 4x4 ?
I am not going to do much to this engine, probably Just leave it stock with standard bolt ons.
Old 02-21-2011, 07:30 PM
05HD's Avatar
Not a heck of a lot. Do something about the VATS.
Old 02-21-2011, 07:50 PM
Ok, well ill be the first one to admit, I know nothing about programming or these computers. Will I need a signal from the transmission? And will a tuner be able to take out the stock transmission settings?
Old 02-21-2011, 08:05 PM
05HD's Avatar
What year are the harness and ecu?
It will run the engine fine even if it throws every trans code there is.
Old 02-21-2011, 08:39 PM
I have 3 computers, harnesses, accessory brackets etc.: one from a 95 z28 A4, one from a 94 9C1 Caprice A4, and one from a 94 Buick Roadmaster A4.
Old 02-22-2011, 07:10 PM
Fazz73jr's Avatar
A tuner will be able to reprogram it to disable Trans control. Basically making it an m6 pcm. Other than that and the vats crap it should be pretty much plug & play! Just don't get that opti wet if you plan on using that 4x4 in the mud or something wet!
Old 02-22-2011, 09:35 PM
LigHtEmUp01's Avatar
you shouldnt need anything because the 4x4 is manual not push button
Old 02-22-2011, 09:40 PM
NewOrleansLT1's Avatar
How will you get your gauges to work?
Old 02-23-2011, 07:52 PM
Thanks for the help guys!
And N.O.LT1...I have a full set of mechanical Autometer gauges for temp, oil pressure, voltage, Tach and the speedometer is still cable driven off the transmission.
Old 02-23-2011, 09:23 PM
Here is a beginning shotof the truck with my kids to show a size reference.
If that don't load, here is the link:
https://picasaweb.google.com/m/viewe...89920957704210
Quick Reply: Swap into 84 Chevy 4x4 ?'s
